Question about Delta PLC DVP14SS11R2 DVP14SS11R2
Dvp14ss11r2 not connected with pc, cable is ok..
What do if my lenovop pc showing only not connection ?
Check if your LAN-cable is plugged into computer and in the other end of cable to wall-outlet/adsl-modem/some router /switch
If the cable is connected is the indicator light on both ends.
Thunder and lightning could have a electrical surge in the internet grid?
Mar 27, 2012 | Lenovo Computers & Internet
When I open the Monitor (samsung syncmaster 710n) everything is OK! As I soon as I connect the vga cable from my pc the monitor turns on stanb by mode and does not react to any buttons!
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Feb 10, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
Hi,I just want to know the connection diagram of lg 17"crt monitor cable which is connected to cpu end,my cable is ok but the thing is one end is disordered which is fitted with 15 pin connector...
Don't know what you mean by "disordered" the signal cable is a male connector at either end. Are you sure you are trying to connect it to the correct port on your PC?
Does your PC have onboard graphicis or do you need a seperate video card?
Dec 23, 2010 | LG Studioworks 700S 17" CRT Monitor
I have a samsung corby gtb3410.When i connect my
when u connect ur phn with data cable u hav to choose mass storage option to use ur phone memory n card memory on PC it appears when ur touch pad is unlocked and u connect it to pc
Apr 21, 2010 | Samsung Cell Phones
Will not recognize the PC. USB cable OK. Memory
Use a card reader to download your pics...works every time.
Mar 28, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Self test flashes for a few seconds comes when power is connected and then power is lost
check us power cable that is ok? and also check ur usb cable which is connected with the pc. if power cable is ok then i think its ur hp power button fault. then repair ur power button. then it become ok
Aug 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Problem in connecting nokia n72 with pc..
pc suite install after n72 sofware insert cd rom now data cable conected phone to pc find new hjadware plse search install the driver file, two times try it
Jul 10, 2009 | Nokia N72 Cellular Phone
My W810i phone is not connected to pc suit even my phone is connected by USB cable
Thank you
My Problem of not connecting my phone to pc suit is solved.
by running pc suit cd only.Ok
Sanjay
May 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Cant get connection from pc ..to mobile (ok from mobile to pc)
well the best way to connect your mobile with computer is through data cable.. you should have nokia N73 data cable (DKU-2) and download nokia pc suit from nokia website..
Oct 04, 2008 | Nokia N73 Cellular Phone
Delta PLC DVP14SS11R2 DVP14SS11R2 Logo
44 people viewed this question
Top Delta Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Delta Office Equipment and Supply Expert? Answer questions, earn points and help others
