Question about JAGUAR S-TYPE Jaguar S Type Stype Climate Control 00 01 02 03 Rebuild
Jaguar stype won't start
Jaguar stype 3.0 was working fine now won't start just clicks, no interior lights dash displays all eror codes from abs to dsc. Cas is stuck in park only drivers door locks on key fob.
Changed battery on my 2003 S-type v6, starts fine, runs fine but all the lights in the dash are on. How can I reset?
Disconnect the battery for 5 minutes and connect it back up again and re-check.
Were these same warning lights displaying before the battery was replaced?
Nov 18, 2015 | 2003 Jaguar S-Type
Interior lights won t turn on
It can be one of two problems. One: pending on what kind of car you have. ..there is a switch near the steering column that turns left or right...adjusting your dash lights and or turning on/you interior lights.#2...check the interior fuse bus panel/box
May 22, 2014 | 2005 Jaguar S-Type
Car wont start 1996
the ecu controls the power to the pump and injectors. are you getting error on every test on reader that can be the ignition relay. its in the dash when you turn the key should hear it go click click. if just one click then one side of it has gone. there is the low volt side, ignition interior dash lights etc. high volts is ecu abs, air bags. etc. low volts go to the abs and ecu but when engine started it needs the high volts to be there to run.
Oct 27, 2013 | Chevrolet Caprice Cars & Trucks
My 04 jaguar stype over heated yesterday, Now it won't start???
Yes, it could be the cylinder head gasket. That should probably be the first thing you should have checked. If it overheated bad enough, it can also warp the head necessitating machine shop work to true it up again.
Jun 19, 2012 | 2004 Jaguar S Type
I have a 2008 grand caravan and I have three warning lights on at the same time. The lights are the ABS,traction control, and the ESP\BAS,all are yellow .The van is running fine except after driving for a...
Stop using it and have it diagnosed and repaired
Don't mean to be hurtful here, but you surely have to
know you have several diagnostic trouble codes
present,as indicated on your dash
Those type of lights have been on vehicles for
30 years now
Keep driving it, and you will possibly start to do
some expensive damage or have an unsafe vehicle
Mar 15, 2011 | 2008 Dodge Grand Caravan
We have a '94 XJ6, I get nothing from a run>>>start.
there are 2 connections on the bulkhead/firewall. There is one on
each side.The connectors are brass and the insulators are
plastic with a rubber boot. unless these connections are clean you may get all sorts of malfunctions with switches,lights and electric
motors. Symptoms are similar to a failing battery, something to start with..
good luck
Apr 01, 2010 | 1994 Jaguar XJ6
How to unlock truck jaguar stype when no power
The button or the fob will not work with low or no battery power - you need to use the key. There is a keyhole on the boot under the trim or under by the reg. plate lights according to what facelift model you have.
good luck.
Sep 27, 2009 | 2002 Jaguar S-Type
Engine management light
P1388 Variable Cam Timing Overretarded (Bank #2)
This is a Jaguar specific code.
Jul 10, 2009 | 2000 Jaguar S-Type
Car won't start!!! & ABS Light on
Sounds like carbon build up on the contacts inside the electrical ignition switch which is not the key cylinder. Its located on the lower steering coluum if coluum shift or if you have a floor shift it will be inside the console
May 29, 2009 | 1995 Oldsmobile Cutlass Supreme
Jaguar 2.1 litre petrol will not start
jump start vehicle with commercial grade leads and see what happens,,might just need a new battery sounds like its low and has no reserve amperage although a volt check will show ok,or test it with a proper discharge gauge to see if a cell has packed up.
Dec 20, 2008 | 2002 Jaguar X-Type
JAGUAR S-TYPE Jaguar S Type Stype Climate Control 00 01 02 03 Rebuild Logo
749 people viewed this question
Top JAGUAR S-TYPE Video Game Consoles & Games Experts
James Wishart
Are you a JAGUAR S-TYPE Video Game Console and Game Expert? Answer questions, earn points and help others
