Question about Toshiba V3100 PC Desktop
Toets voor umlaut - Toshiba V3100 PC Desktop
Keyboard types umlaut instead of quote
probably a "accessibilty" setting or a keyboard flaw. try to turn of all accessibility options and swap you keyboard with a standard usb one. hope it help
Dec 12, 2014 | HP Computers & Internet
Type umlaut
Found this at http://desktoppub.about.com/cs/finetypography/ht/umlaut.htm
It works for mac and windows.. You will need to key in the ANSI code. Hold ALT key type in the ANSI code example is 0196
gives you cap A with the umlaut on top. Hope this answers your qestion
Sep 07, 2014 | Acer Aspire Computers & Internet
Ik heb nieuwe kaarten benelux gedownload( en betaald) maar ik krijg dit niet in mijn navigator. Ik heb wel eerst alles verwijderd.Voor het installeren heb ik een productsleutel gekregen maar het wil niet...
Neem contact op met de klantenservice voor uw apparaat. Het klinkt als ofwel de nieuwe sleutel die je kreeg was voor een andere versie, of er is een andere fout in de toets.
May 04, 2014 | Navman GPS
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
Apr 21, 2013 | Computers & Internet
ZZR 600 bj 1991 HIJ vonkt WEL mare start niet Signature Mij Staat sterven niet op Tijd en IK vind De Vonk niet Echt Krachtig Nieuwe Bougies Nieuwe Kabels bobines zijn gelijk AAN Elkaar en de omse...
Hallo, P_kok en de gebruikelijke verdachten zijn:
1. Brandstoftank leeg.
2. De brandstoftank heeft oud dode gas.
3. Brandstoftankbodem vervuild met ethanolslib, vuil, water, roest, enz.
4. Brandstoftoevoerklep / petcock uitgeschakeld.
5. Verontreinigde bougies.
6. Motor overspoeld als gevolg van overmatig gebruik van de choke.
7. Vacu?mslang aan de brandstoftoevoerklep / petcock ontkoppeld, gebroken, gebarsten of geknipt.
8. Brandstofklep / petcock of filter verstopt.
9. Brandstofleiding naar carburateur of gaslichaam ingeklemd, geknikt of geblokkeerd.
10. Carburateur drijft vast.
11. Brandstofinjectoren verstopt.
12. Brandstofinjectoren steken open.
13. Ernstig ontladen of beschadigde batterij moet 12,5 volt of meer hebben en in voorkomend geval een correcte "LOAD" -toets kunnen doorgeven, u kan een cursieve lezing van 12,5 volt of meer hebben, maar weinig of geen stroomvermindering is de batterij defect en moet vervangen, AGM batterijen falen in dit scenario meer dan lood-zuur batterijen.
14. Controleer de batterijterminals voor beschadiging of corrosie. Controleer de batterijkabels op "BOTH" uiteinden voor losse, corrodeerde of gebroken connectors, "INSIDE" en buiten de kabelhaken, voer de connector wiggle test en controleer de kabels met een ohmmeter indien nodig.
15. Losse of gecorrodeerde draadaansluiting bij de spoel of de stekker tussen de ontstekingssensor en de ECM-module.
16. Stekkerkabels in slechte conditie en korting controleren op vonklekkage in het donker, kabelverbindingen los of aangesloten op de verkeerde cilinders.
17. Ontstekingstijd niet correct door een defecte ontstekingsspoel, ontstekingsmodule of MAP, CMP, CKP, O2, TPS, ETP, IAC sensoren.
18. Foutieve neutrale, koppeling, kickstand veiligheidsschakelaar. 19. Foutieve brandstofpomp of zekering of relais.
20. Een vast gebogen of verbrande klep.
21. Tilt sensor heeft een reset nodig.
22. Beveiligingssysteem dat alarm niet uitschakelt, heeft een reset nodig.
23. Controleer de motorcodes van de motor.
Voor meer informatie over uw probleem en waardevolle "GRATIS" downloads die u nodig heeft voor het bekijken of afdrukken, klikt u op de onderstaande blauwe links. Veel geluk en een geweldige dag. ZZR600 starting problems Horizons Unlimited The HUBB
ZZR600 ZX600 1991 infrequent or weak spark during startup
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 16, 2017 | 1991 kawasaki ZZR 600
I need calibration instruction for Mettler Toledo IND690 and ID3sTx, please
I WANT TO CALIBRATE METTLER TOLEDO IND - 690.. PLEASE ME..TEACH ME HOW
Oct 21, 2009 | Zebra Printer 140-751-00000
I can't write umlaut on my laptop hp ..help meeeeeeeeeeeee..if can explain it in italian it would be better.. thanx
there are different ways to do different characters on different computer keyboard configurations......here is the long way
you will type in the code next to the letter to get the desired effect
a umlaut Alt 0228
e umlaut Alt 0235
i umlaut Alt 0239
o umlaut Alt 0426
u umlaut Alt 0252
y umlaut Alt 0255
HOLD ALT WHILE TYPING THE NUMBER SEQUENCE!!
gOOd LucK!!!!
Mar 10, 2009 | HP Compaq nx6110 PC Laptop
Printer not print/Don't understand language so can't fix
find your manual in your language here and follow language setup instruction to your display in your language
Jan 26, 2009 | HP LaserJet 4050n Printer
Mijn nieuw gekochte CD150 telefoon blijft 'hands aanmld' aangeven sinds ik heb geprobeerd een 2e toestel aan te sluiten. Ook resetten lukt niet
Philips CD150 of CD 150 telefoons. Probleem als je 'Hands Aanmld' op t display houdt
Neem aan dat je er inmiddels uit bent. Had vanmiddag t probleem ook. Ging zover dat ik de telefoon wilde openschroeven om te kijken of ik ergens een knoopcelletje (batterijtje) even kon wegnemen en terugplaatsen. Is niet nodig. Oplossing is eenvoudig, maar je moet even uitproberen.
Druk 5 sec op de knop op t basisstation (de houder). Neem één vd telefoons, druk op menu en ga naar advanced instellingen, selecteer registering en toets daarna de pincode (0000) in. Minuutje wachten. Daarna zelfde procedure voor de andere handsets.
Succes ermee!
Ed van Rijckevorsel
Dec 07, 2008 | Lands Phones
Toshiba V3100 PC Desktop Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
