Question about Samsung HM1500 Bluetooth Headset
HM1500 LAST NUMBER REDIAL
The headset's last number redial function is causing many problems, keep redialing numbers by mistake when the button is accidentally pressed (from the seat belt or when in my pocket). How can I dasable the function
3 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Samsung WEP200 Headset
Hello Sir,
You must be frustrated by this problem. It should be easy to solve. All units transmitting on an open channel have a unique identifier. This is the Pass Key.
1.) Check under the transmitter and there should be some numbers. The one above the bar code is usually the passkey, but it could be another on the label so write them all down.
2.) Click on the Blue icon next to your time display in the System Tray.
3.) Double Click your bluetooth headset and when prompted for the passkey enter the first number you wrote down. If that does't work try the others. One of them is your passkey.
If you need further assistance comment back to me and I'll be glad to help.
Kind Regards,
Worldvet
Posted on Jun 01, 2008
  • 54 Answers
SOURCE: last number redial hm1500
Please define/ give more input of your problem/ requirement!
Posted on Feb 12, 2014
Last number redial
press the redial button and the number will appear
Nov 23, 2015 | Cell Phones
Last number redial hm1500
Feb 12, 2014 | Samsung HM1500 Bluetooth Headset
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
HOW TO USE RECALL KEY OR HOW TO USE THE REDIAL FUNCTION
Don't confuse the two. In most systems, the RECALL button gives you new dial tone on the line you're currently on, and the REDIAL function will dial the last number dialed or a saved number.
Since you're asking about a phone and did not list the SYSTEM, if you set has Last Number (LNR) or just redial, when you press the button, it will either try to use the last line dialed, or you may have to select an outside line and get a dial tone, then press the LNR button. It will dial out. If you press the RECALL button, it will drop your present call and give you new dial tone without having to hang up, pick up the handset, and select a line. You may actually have to press both buttons to effect a LNR sequence.
Carl
Aug 18, 2010 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
Sep 14, 2009 | Panasonic Lands Phones
Recall last phone call to see number
Press "Redial" then *(star). The redial key is a multifunction key. You can either use redial or utilize the phone system speed dial directory.
Jan 09, 2009 | NEC DTH-8D-1 Corded Phone
Redial last number called when turning H700 on
If you are turning it on with the button, that is why. To turn on the H700, you should just need to open the boom mic. Once open, it should connect with your phone. The H700 is designed to dial the last number when the button is pressed. No way around this one.
Dec 01, 2008 | Motorola Mobility H700 Wireless Headset
Samsung HM1500 Bluetooth Headset Logo
63 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
