Question about Whirlpool LER4634J Electric Dryer
Need a wiring diagram for a Whirlpool 5700 lhe
4 Suggested Answers
  • 30 Answers
SOURCE: LHE 5700 tumbles but no heat
Sounds like your heating element has burnt out.
Posted on Nov 16, 2009
rickzilla
  • 706 Answers
SOURCE: Whirlpool Dryer - Model LHE 5700. My Dryer had
Hello David_Teresa,
Under the new Codes...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the neutral from ground to provide additional safety for the user.
Hope this helps,....
Posted on Nov 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool dyer LHE 5700/LHI 5701
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Posted on Oct 01, 2010
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
LHE 5800: timer not working and not heating up
Have the timer checked and the heating element.
Jan 26, 2013 | Whirlpool Dryers
Assembly diagram for 5700 power shot
I hope this diagram helps. I used it to help re-assemble my powershot 5700m.
Gail
Jun 13, 2012 | Black & Decker 5700 Powershot Forward...
Need repair manual for whirlpool LHE 4930 (old) to replace belt or find what other problem may be keeping the drum from turning
Type in Google search for the manual. if one exist it will be there. Just type in --manual for whirlpool LHE 4930 washer. 99.9 of anything printed is somewhere or can tell you where on Google search
May 31, 2012 | Whirlpool Dryers
Whirlpool Gas Dryer I need the wiring diagram of Whirlpool WGD 5000
Here is a link to your diagram, Whirlpool prints both gas and electric models on the same page, since yours is gas use the bottom diagram.
Let me know if you have questions.
Tech_Sheet_01_20_2010/Wiring%20Sheet%20-%20W10185979.pdf
May 05, 2010 | Whirlpool Dryers
Whirlpool Dryer - Model LHE 5700. My Dryer had a 3 prong plug. I recently built a house which has a 4 prong plug. I changed out the plug and connected the wires according to color. The center wire is white...
Hello David_Teresa,
Nov 29, 2009 | Whirlpool Dryers
Nov 16, 2009 | Whirlpool LER4634J Electric Dryer
Model # LHE 7800 W1 On the thermostat by the heating element Which terminal does the red wire go on?
On a/c voltage , if you have 2 terminals on a part , it won't matter which terminal the wire goes on . There are several red wires in that area ,so if it goes to the thermostat , it doesn't matter which terminal on the thermostat it goes on .
Jul 13, 2009 | Whirlpool Dryers
Whirlpool dyer LHE 5700/LHI 5701 PRESS START BOTTON CAN HEAR CONTACT BUT WON'T STAY ON
Jul 05, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
