Samsung HD321HJ when insert to the computer show window: Disk is not formatted do you want to format it now ets... have windows HP. What to do ?
  • 56 Answers
Disk needs to be formatted before it can be used
Posted on Mar 22, 2014
DarkNeogen
  • 109 Answers
SOURCE: Windows not able to detect Hard Disk in My computer
1. Rightclick on your "My computer" icon.
2. Doubleclick the Manage option.
3. A screen will appear called: "Computer Management".
4. In the tree on the left you see "Storage" and the option "Disk Management" below it.
5. Select "Disk Management", and locate your SimpleDrive.
What does it say? If it shows only "Unallocated Space" you'll need to create a new partition on it. (Right click the unallocated space, then it'll show some options). If it is allocated, try formatting it. If you don't see your drive > reconnect it.
Let me know if this helped. Please rate.
Greetings,
DarkNeogen.
Posted on Jan 25, 2008
SOURCE: Will not read or format.
I had the same problem with a 1 gig Cruiser Micro and I did something that brought it back to life...I used the U3 Uninstaller on it even though I had already done so and it was already gone and I was then able to open the flash drive and write to it again...go figure!
Posted on Feb 05, 2008
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
  • 2668 Answers
SOURCE: 2gb memory stick became 8mb and it says disk is
Windows cannot format USB memory sticks, you need the HP USB memory format tool . Get it here.
http://en.kioskea.net/telecharger/telecharger-127-hp-usb-disk-storage-format-tool
Posted on Dec 16, 2009
laikexpert
  • 281 Answers
SOURCE: formating raw usb flash disk
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
My hp mini 2140 laptop says non disk or disk error hoe do I fix it
You must try to format it with a disk installer (windows cd).. During the process of formatting it will show the HDD is exit or not. If it not exist means the HDD is physically damaged. Or you will be ask for the partition to install windows on it
Jan 19, 2017 | HP Computers & Internet
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 22, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
I have transcend 2GB pen drive. when i insert my pen drive in system it shows the removable disk icon in MyComputer window . when i click the removable disk it shows 'please insert disk' ...i cant open the...
may be the flash drive is locked...unlock the pendrive and then try again.
formatting can be done in other way.
goto run,type cmd,press enter,then type format f: in the cmd and press enter.this formats the drive
Sep 09, 2010 | Transcend Computers & Internet
What is drive g ?
There may be a virus attack and i think it must be showing o bytes space as well. well the chances are 50 percent. but lets try....now you have to format the usb there is no other option and windows wont allow you to format.Download the software HP disk format from the link below.
Install and format the usb with hp disk format tool. the link is below:
http://www.mediafire.com/?c4yejtzywyz
And do let me know if that fixed your problem.
Jul 28, 2010 | Dynex USB 2.0 5-in-1 Memory Card Reader
I am trying to copy photos to a cd-rw. i insert
Try another disk.
One problem with CD R/W is that some programs insist on formatting them. If you have "In-CD" running, shut it down and try again.
Dec 22, 2009 | HP Computers & Internet
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
Million thanks for the one who solves this for me
Hi Sweet_Rascal,
If I understand you right, all you want to do is to successfully complete the format of a 4Gb Jet Flash/Transcend Flash Drive. You were unable to complete it using the Windows built-in format function. Further you can not access, read from or write to the said flash drive.
May I suggest you to use HP Drive Key Boot Utility instead of the Windows built-in format command.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
