Troubleshooting tv problems
Tv changes channels on its own
Try Auto rescanning your tv channels.
If still same then maybe aerial needs adjusting slightly
Aug 10, 2014 | Bush Universal Flat Screen TV Swivel Mount
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
Attempting to retune channel 5 was asked to return to factory settings answerd Yes and lost picture, sound and channel changing still O.K.Please advise.Don.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Problem retuning syncmaster 933hd tv
Oct 01, 2009 | LG W2353V-PF 23' LCD Monitor
No responding to remote
Unplug the TV from the AC Power source (wall socket) for about 10-15mins and then replug and see if it works.
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Ilo 260tv remote does not work
This looks to be a problem either on the IR circuit board or in the microprocessor that controls these features and controls. I would suggest since you have tried to change channels from the TV itself that the problem in the processor is the more likelyoption. In this case I would say since this would involve a lengthy troubleshooting procedure, That you may have to take your TVs to a qualified TV repair facility for servicing since the procedure may be beyond just replacing a part, and may involve actual electronics troubleshooting. Having owned a shop for some time I can tell you that some items are only repairable at TV shops.
I hope this helps, Thank you, Shuttle83
Jan 16, 2008 | iLO 2600 Television
Stuck on channel
Hello All,
This looks to be a problem either on the IR circuit board or in the microprocessor that controls these features and controls. I would suggest since you have tried to change channels from the TV itself that the problem in the processor is the more likely option. In this case I would say since this would involve a lengthy troubleshooting procedure, That you may have to take your TVs to a qualified TV repair facility for servicing since the procedure may be beyond just replacing a part, and may involve actual electronics troubleshooting. Having owned a shop for some time I can tell you that some items are only repairable at TV shops.
Jan 05, 2008 | iLO 2600 Television
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
