Question about Dell Computers & Internet
Secret codes dell serial number check
  • muhammad haseeb
    muhammad haseeb Feb 12, 2014
    Hi muhammad haseeb, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Master:
  • Dell Master
  • 788 Answers
You can use the Service Tag number (it is located on the bottom of the laptop, or in the BIOS) to check the laptop status with Dell.
Posted on Feb 18, 2014
Need unlock code for radio serial number M038262
There is no special secret code - you have to just keep trying codes until you get the correct one or send the unit back to the manufacturer.
May 01, 2017 | Cars & Trucks
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
Find serial number
On Dells the serial number is usually on the top of the PC
It would be on a black sticker and will have a serial number and an express service code
Aug 18, 2014 | Dell OptiPlex 3020 Desktop Computer -...
Where do i find the serial number
It is on a small sticker on the bottom of the computer, smaller than that of Microsoft COA. You can find there the service tag and the express service code. you can also check for the service tag in BIOS (press F2 during startup) and you can also check for express service code in start - programs - dell accessories - express service code.
Sometimes the actual serial number is under the battery, but generally all you need is the Service Tag (on the bottom) when dealing with Dell.
Jun 19, 2012 | Dell Latitude E5520 Laptop Computer PC...
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Imei 35454001633758 i need security code
Jun 28, 2011 | Nokia 1110i Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
I can't find the serial number for my computer. Kindle is asking for me to register my device and ask for this number. They say it's 16 digits. Can you help?
The serial number for Dell's is actually the service tag, which is a 7 digit code usually located on the bottom of the device. There is also an express service code which is an 11 digit number used by Dell for support. Kindle is most likely asking you for the serial number for a Kindle E-Reader.
May 12, 2011 | Dell Inspiron 6400 Notebook
KEY CODES FOR SAMSUNG YP-T9JB
Samsung Secret Codes Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: ...
Jul 12, 2009 | Samsung Yepp YP-T9 Digital Media Player
Master key code
Go to http://wii.marcansoft.com/parental.psp and enter your 8 digit confirmation number there. When you do so, make sure that whatever today's date is, your Wii is set to that date. (And select Today's date from one of the 3 possible choices.)
(To get the confirmation number, go into Parental control settings, click I forgot on enter pin screen, and Click I forgot on answer secret question screen. This is where you come to where you enter the master password, and the confirmation number you need, to get this master password.)
Apr 22, 2008 | Nintendo Wii Console
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
