Question about Sea-Doo US SeaDoo RS2 Seascooter
When i plug in batterty that is dead it take al littlewiggling to have charger light turn red after charging for 8 hrs light is still red ; It appears no juice in battery. Unit was purchased dec 2012 charged maybe 24times
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sea-Doo US Master
  • 1,190 Answers
See what volts are there with a multi meter ! if showing 10, 12v then get the battery drop tested with special tester to check all the battery cells dont bubble up as this says battery is duff ! is your charger ok ?
Posted on Jul 08, 2014
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
Will not turn on
Nook tablet won't charge
Jan 16, 2015 | Tablets & eReaders
My makita battery is not taking a charge is it the base or the battery
The most easiest way to be sure is using multimeter. 25290419-3h5pkc2unruv115jj1tsixdi-2-0.jpg
Set your multimeter to highest dc volt. All chargers have output voltage information written on it (Must be written as "output" value or "sec"). Measure charger's output pins (which connects to battery) and be sure measured value matches with output voltage value written on charger label. If it doesn't match each other, buy a new charger and proceed with below part.
Discharge your battery. Once you discharge battery; be sure that there is no charge at all. Charge battery for 15 min. Measure battery power with multimeter again. If there is no charge at your battery, it is dead and you need another battery.
Nov 19, 2014 | Makita Drills
WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Apr 03, 2010 | Air Hogs Radio Controlled Storm Launcher...
Battertys wont charge light on charger is on mains but orange charging light does not light to indicate that batters are charging and has been left uncharge for 4 months
dead batteries; these batteries drop so low when not in use that wheelchair chargers can not bring them up, sometimesa trickle auto style charger can bring them up
Apr 18, 2009 | Jet 3 Ultra Power Chair
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Sea-Doo US SeaDoo RS2 Seascooter Logo
76 people viewed this question
Top Sea-Doo US Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
Richard Lilja
Richard Lilja
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
