Soft starter now has been replaces 3 times - Heating & Cooling
Starter on my 91 ford ranger 4 wheel drive starts my pickup a couple time then it just spins have changed it 3 times now
Assuming the starter motor spins but doesn't engage to turn engine over to start you could have a bad starter drive which is part of the starter assembly or possibly damaged/missing teeth on flywheel ring gear. Depending on year and model vehicle, some starters you can replace just the starter drive otherwise you need to replace the whole starter. If you changed the starter look at the flywheel.
Sep 18, 2014 | Cars & Trucks
When I replaced ignition switch in a 2000 buick centery I stll cannot get power to starter and power windows ,gas guage and radio don't work
Sounds like the Ignition switch wasn't the problem, check your fuse links at starter, they are soft fuseable wire that will burn if shorted or even when they get old over time they will go bad. they are the smaller like #10-12 ga. wire , should be at least 1 maybe 2 of them at harness connection to starter.
Aug 30, 2012 | Buick Century Cars & Trucks
I check glow plug, they are good.check air filter good. check fuel pump good check injectors good. i was told may be the compression is low.could you give me your advise before i buy a foreign use...
It sounds like your car won't start?If you can find the starter,get a hammer and tap on the starter 3 or 4 times and try to start.Not too hard,not too soft.Even if it doesn't start the first time,try several more times.If the car eventually starts it's the starter.That is just the nature of starters.They don't exactly fail,they just get tired I guess,it's hard to describe.Good luck! Greg
Sep 18, 2010 | 1988 Mazda B2200
I have a 1992 honda accord it will start one time and not then next once its started it runs great but never know when it will start or not?
Keep a hammer in your trunk.If it doesn't start,tap on the starter with a hammer 3 or 4 times,not too hard,not too soft.,then try to start.It may take several tries.If you don't know where it is,call a dealer or a shop,someone will give you the free information.It sounds like the starter.They normally do not faill 100% but yours is still in better shape than most I hear about.Good luck! Greg
Aug 20, 2010 | 1992 Honda Accord
Car making clicking noise when trying to start
It's clicking multiple times without starting?Locate the starter.If you're not sure where it is,call a shop or a dealer and they will tell you free to attract future business.Tap on the starter 2 or 3 times with a hammer,not too hard,not too soft then try to start.It may take several tries but it should end up starting meaning...you have a bad starter. Good luck! Greg
If that is not the case,just reply to this post and I will get an auto email saying you commented.
Aug 19, 2010 | 2006 Buick Rainier
My 2002 impala wont start i just hear a click when i turn key
You have a dead Battery, have the Battery tested, it should have a static charge of at least 11-12 volts, if lower than that, replace the Battery.
Aug 13, 2010 | 2006 Chevrolet Impala
When you first start the car in the morning, everything is fine until you get to where you are going. If you try to restart car once you get there, the starter is totally dead. If you let it sit for an...
Either your starter is going bad or you have a bad ground. More then likely it's the starter. The by the book answer is the check your grounds and power the starter with the vehicle hot, if both are good then replace the starter. The back yard answer is, next time it won't start try tapping the starter with a small hammer. (not too soft, but not hard enough to dent the case) Sometimes that does work, but I'm still gonna say prolly a starter.
Dec 19, 2009 | 1998 Ford Taurus
Periodic no-start
You have worn contacts on the starter solenoid. This is a rather common problem. Attempting to start it 2-3 times moves the contact slightly, and then it starts, by making good contact. You have 2 options: 1) Replace the starter and 2) remove the starter, and have the contacts replaced by a starter rebuilding service. The 2nd option would be the cheapest rout, as opposed to a replacement starter. Hope this helps you out.
Thanks for choosing FixYa for assistance!
Jan 31, 2009 | 1995 Toyota Camry
Illustraited instructions to remove a starter from a Harley soft
no pictures 1 remove the battery neg cable, 2 remove the primary chaincase on left side or bike it is held on with 3/16 allen bolts be ready to catch the oil thats comes out (3/4 of a quart replaces it) 3 remove the small 3/8in bolt that is in the center of the starter shaft (small gear at top of case) 4 go to other side and look at starter see the two large allen bolts at sides remove them now with a little pulling it will squeez out from under the oil tank if not loosen rear oil tank bracket that will help this should help you
Dec 25, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
