Question about Sewing Machines
How do I fill spool on Harmonie 400 - Sewing Machines
I would like a manual for a Singer Harmonie 200 .
Google, manual Singer Harmonie 200. You will find a link for a free download there.
Aug 07, 2016 | Singer Sewing Machines
Can't fill empty spool
The bobbin winder has a small rubber tyre...probably damaged or broken and needs replacing
Jan 07, 2014 | Brother XL-2230 Mechanical Sewing Machine
Model Singer Harmonie 400
contact the singer website customer service and ask them about oiling the sewing machine...
May 27, 2013 | Sewing Machines
I would like a singer harmonie 400 model user manual please
The only model 400s I found were old, like 1940 old. Here's a page of way older docs... scroll down to the 400s and open a few to see if any one of them are the right one for your machine.
http://www.parts.singerco.com/IPinstManuals/
Good luck
Oct 05, 2012 | Sewing Machines
Manual for singer sewing machine harmonie 300
The Singer Harmonie 300 is the USA Model 9134. You can download the PDF from this link, which is at the Singerco.com website: http://www.singerco.com/uploads/download/2d743e26f022a5a8d564c0fbeaad865bc4b7d00e.pdf
Jan 11, 2012 | Singer Sewing Machines
I am totally new to machine sewing and I have a Husqvarna Model 400, its been working perfect then suddenly when sewing the thread from underneath (the spool side) is just coming out in huge clumps, the...
When you say "the spool side" I assume you mean the bobbin. There are a couple of reasons why this could be happening. First re-thread your upper thread with the presser foot up and check to see if the top thread is firmly in the tension disc. Usually when you have looping of thread on the underside of your fabric, it is the upper thread that is out of whack. Just the opposite of what you would think! When you're sure the top thread is right check your bobbin to make sure that's wound tight and not "mushy." When you start by wrapping the thread around the bobbin by hand and then put it on the winder to fill it, it is not tight enough so the whole bobbin winds too loose. This can cause clumps underneath. The last thing to check is that the bobbin thread is caught in the tension slot in the bobbin case and that there is no stray threads in the bobbin case opening to cause trouble. Hope this helps. Good luck. You have a great machine!
Sep 10, 2010 | Husqvarna Sewing Machines
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
