Question about Inverter KEB COMBIVERT F5
What Error COM KEB mean ????i have F5 version
Please can somebody tell me what Error Com KEB deal with ???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Posted on Feb 13, 2014
3 Suggested Answers
SOURCE: F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Posted on Apr 11, 2010
  • 4 Answers
SOURCE: Hi i m using keb
Assignment of Interface Pin 1 not used, Pin 2 TxD Transmitter Signal/RS232, Pin 3 RxD recever signal/RS232,
RS 232 cable part number 00.58.025-001D Length 3 meter
(9 pins SUB-D Female) 2--------------------2 (9 pins SUB-D male)
3--------------------3
5--------------------7 Must be use the shielded cable & one side body connect with shielde
I think its will work
Posted on Jun 08, 2013
We have KEB Combivert F5 drive Matno. 15F5C1E-350A Version. drive is installed in machine and is not working right now.i want to run the drive in Manual mode to test it.
if the display says LS, it means you are missing the speed and direction command. Via the keypad, provide the direction and then the speed.
Mar 07, 2015 | Inverter KEB COMBIVERT F5
Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
Apr 01, 2014 | Inverter KEB COMBIVERT F5
E.pu error in keb f5 inverter. the part no. is 09.f5.a1d-3a4a, ver. 1.0, 1.5kw. when powering up the drive, it gives 560VDC. please recommend what the problem could be.
The E.pu error is a general power stage failure.
Typically means that the unit has a defective power stage that would need to be replaced.
If it is an old inverter(early 2000's) there is a possibility that it could be a cooling fan problem since at that time there was a three wire fan used. May be able to replace the fan (must obtain from KEB) but there may still be problems with power stage. If it is from early 2000's then you might be better off replacing the unit with new current version.
Mar 10, 2014 | Inverter KEB COMBIVERT F5
Power unit not ready
hi,please you can show picture keb for power unit,or maybe you have another solutions
Oct 04, 2013 | Inverter KEB COMBIVERT F5
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
Sep 04, 2013 | Inverter KEB COMBIVERT F5
My keb combivert f5 ser- no. 02292642/0450840 art-no.12.f5.b1d-3aoa is faulty due to operational error, i want to reprogram it so that it can function very well so please l need a programming manual and...
Go to: http://www.kebamerica.com/en/service-downloads/downloads.html
SelectManuals
Frequency inverter
Language - ALL
The click on search.
You will want to look at the manuals under: Frequency Inverters > COMBIVERT F5 > Control Circuits > Basic (51)
Sep 01, 2013 | Inverter KEB COMBIVERT F5
KEB 07 F5 Error code E. Puch what will cause this error and how do i clear it
E.puch means that at power up the control card did recognized the power stage as different than last time it powered up.
This is normal when the control card is changed. If the control card has not been changed, there is a problem between the power stage and the control card.
Initialize the value at sy.03 to reset the error.
Apr 25, 2013 | Inverter KEB COMBIVERT F5
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 Logo
120 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
