Question about Whirlpool duet Washing Machines
No key for washer coinbox
Cant get in to coinox on my washingmachine I lost the keyb
    Master:
  • Whirlpool Master
  • 676 Answers
Order and new one call Whirlpool 18002531301
Posted on Feb 13, 2014
Where and how can I buy a replacement keyboard for Yamaha CVP 305M? Thanks, Michael
There is a well documented problem that occurs with the keybed on some of these models due to a manufacturing fault. Take a look at the keys that are sticking. Is the gap on either side of the key the same ? If not then the key normally leans slightly to the left rubbing on the adjacent key causing the sluggish action. The fixing tab at the back of the key breaks causing the spring pressure to push sideways.
You can just replace the offending key but the problem will eventually return. You could replace the whole keybed but this is a very expensive fix.
Keys are around £ 15.00 each.
Replacement keybeds around £ 450.00
Visit www.beckettsmusic.co.uk
Search for VU101 via the search box.
Feb 23, 2015 | Yamaha Full-Size Keyboard
How do I replace one key?
You will need to gain access to the keybed, remove screw from back of keybed the fix it to the base of the keyboard. Slide the keybed back making a gap of about 2cm at the front of the keybed.
Look at the back of the key towards where it pivots and you will see a small arrow, push something like a credit card between the keys at this point and the key will pop up, you can then slide forward releasing the key.
If you need more info please ask.
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
Need fuction key to turn on internet for gateway ne71b series
push function keyb and Wiffi keyb at the same time and this is all coment please !
Apr 11, 2014 | Computers & Internet
I recently replaced mobo of nv 52, now keyb doesnt work optimal, only 689+-8[yrewkl 1 keys. tried playing with connector, no dice. i type with onscreen kb now. plse advise
If your external keyboard works fine then it is most likely your laptop keypad problem. otherwise the replaced mobo has problem in its keypad connector point. was it a repaired mobo or completely new one?
Keypad is cheaper in e-bay but buy with caution. there are too many without obligation to humans.
Dec 02, 2012 | Gateway nv Computers & Internet
Roland Piano 600 HP 600, out of 76 keys, Keys# 4, 9, 10,11,12,13,14,15, 23, 38, 74 will not play( no sound). Any ideas? Everything else works. Have taken no actions to fix yet.
There is a rubber "bubble contact" strip under the keys, and pressing on a key pushes the bubble down, which makes contact with the circuit board underneath. Any foreign matter that gets in the way of this contact will render that note unplayable, and that is likely what has happened. You can remove the keybed, remove these strips, and clean the board with rubbing alcohol. Don't use alcohol on the bubble strips, as it is not good for the rubber.
Sometimes, you can simply tape a small piece of cardboard, like from a cereal box, onto the bottom of the key where it pushed on the bubble, and this can fix the problem.
The bottom line is that you will have to remove the keybed, and that may be a daunting procedure unless you're used to that kind of work. So you may want to just take it to a service center. You can get parts at www.syntaur.com. Good luck!
Feb 25, 2011 | Roland Ep760 76Key Digital Piano
When i turn on my Ensoniq SQ2 it either says Unexpected Event ID 144 or it boots up and plays random notes or when i play notes only a handfull work I looked at the service Bulliten about the problem but...
I'm guessing this is a main board problem. You can get the SQ-1 Service Manual (parts as well) here:
www.syntaur.com/ensoniq_manuals.html
The Service Manual is for the 61-note SQ-1, but that uses the same boards as the SQ-1, just a different keybed. I don't think this is a keybed problem. You can try unplugging the ribbon cable to the keybed from the main board, boot up, and see if you get the same crash. You may get a KEYBOARD CALIBRATION ERROR message, but you can ignore it; if it boots, the keys won't work, but at least you'll be able to see if you get that error message. If you still do, you know it's a main board problem and not anything to do with the keybed. And at that point, your only hope is to replace the main board.
Jan 28, 2011 | Music
Fisher and Paykel Kelvinator Washingmachine All lights on n
too many clothes in the washer maybe
hows about a F&P manual?Gimme a dollar LOL!
Sep 13, 2009 | Fisher Washing Machines
Spilled wine on keyboard of notebook
The wine components remain at the inside of the keyb so they shortcircuit the key operation and produce the error beeps. In most caseslaptop keybs are not to be dissasembled so best solution is to change it.
Jan 13, 2009 | Acer Aspire 5100-5022 Notebook
Lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Sticky keys on Korg extreme
I just changed the key on my Korg Triton Studio 61. It took some time, but it wasn't that hard. You'd better have a power screw driver. I had to take out at least 30 screws.
Do this at your own risk. Don't blame me if you mess up your keyboard. I'm telling you. If you're not that handy, don't try it. Pay attention to detail and be careful.
The Steps that I took
1) Turn your keyboard face down. Make sure you put it on something soft so that you don't scratch the face of your keyboard or damage your knobs or the pitchbender.
2) Remove all the screws on the bottom panel and remove the panel.
3) you have to take the entire keybed out. Lots of screws! I had to remove the "assignable - midi input/output board" to get it out. MAKE SURE THAT YOU DISCONNECT ANY CABLES THAT CONNECT THE KEYBED TO THE REST OF THE KEYBOARD. I had to disconnect the keybed at three different places. These connector cables are NOT strong and if you pull too hard, you WILL break them.
3) Once you get the keybed out, you have to remove the plastic binder that goes at the back of the keybed. It holds the keys in place.
Then Snap the old key out. snap the new key in. Before you unpack your new key, make sure the old one is really broken. I had a key that wasn't broken. It had just come unsnapped. I snapped it back in and it was fine.
Put it all back together again.
I had a broken key before. i got it repaired and it cost me $150. This time I fixed it myself and it cost me $7.50
Mar 02, 2008 | Korg Legacy Collection
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
