Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
All buttons flashing green except for paper and ink buttons, which are red
Printer isn't working. The lights against the paper and ink symbols are steady red. The lights against all the other symbols are flashing green. What should I do?
SOURCE: Failure to print
inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero tengo problemas para escribir no se como me enviaran lq forma de la lectura la pueda ver en español saludos desde chile
Posted on Mar 08, 2008
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
SOURCE: Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Posted on Jun 03, 2008
munnabhai
SOURCE: Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Posted on Sep 21, 2008
gwbm
  • 353 Answers
SOURCE: flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Posted on Feb 01, 2009
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
I have a primera signature 4 ink jet CD printer. It will not print and the left green light on top is flashing very fast.
The printer lighting symbol indicators are messages of replaceable resources either paper or ink. usually the printer is expected to perform until a fault displays a logo either green for functionality, pink of resources shortage, and red for power resources insufficiency. Checking on the printer compartments to ascertian the conditions or replaceabel resources paper, ink, or jams due to paper over loads. Computer messages with printers would display the fault. For example, a printer message on the computer either as print job request unsuccessful or requirng software would be observable from the computer screen.
Jan 14, 2011 | Primera Technology Primera SignaturePro CD...
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
After turning on the printer both red lights blink and the paper and ink seem ok
Take the scrap paper with the pads on to your sink, turn on the hot tap and hold .... And the printer is not Ready and the two red lights are blinking Please Give ... C46an isn't off but both green and red lights are flashing (new ink was put in .... Nothing seems to happen, except for the printer going through its ...
www.hm2k.com/.../parts-inside-your-printer-are-at-the-end-of-their-service-life
Dec 03, 2009 | Office Equipment & Supplies
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
