Question about Exercise & Fitness
Impulse 9 How to operate
On the 1974 xlch Harley Sportster 1000cc kick start is there a way to retard the spark on startup?
early harleys have an impulse magneto as the ignition system
that means that as you press on the crank pedal the piston moves up , the magneto is held back by a spring until it reaches a set timing point at which point it releases for maximum spark
the method of start this type of equipment is to kick start slowly and not as you would for conventional type kick start
you have probably noticed that if you try for a fast kick start it tends to throw the lever back up under your foot
Just an aside here --there was a joke about harleys with electric start--if it back fired your thumb would get broken
joke based on the fact of the impulse magneto that was replaced with an electric start system
the impulse magneto operation is what gives the harley the strange idle operation
get a harley workshop manual or talk to a harley service center for correct ignition timing of the impulse magneto
Nov 27, 2016 | Motorcycles
What does this code mean? No tach signal to ECM - No Distributor Reference Pulses{4}
ISUZU INFORMATION AND LINKS - Front Range 4x4 Forums
www.frontrange4x4.com > Forum > Tech Topics > Make & Model Links
Apr 7, 2008 - 8 posts - ‎2 authors 12 No tach signal to ECM - No Distributor Reference Pulses{4} ... solenoid circuit failure - 1987 and 1995 Amigo/Pick-up, 1989 to 1994 V6 models ... {9}-Amigo, Pickup,Rodeo & Trooper w/2.6L engine & 1988-91 Impulse.
Sep 18, 2015 | 1995 Isuzu Trooper
Silicone rubber pad for impulse heat sealer
http://www.pack-secure.com/Auto-Sealers_c_531.html
Dec 04, 2013 | Aie Silicone Rubber Pads For Automatic...
What is an impulse sealer?
An impulse sealer heat-seals objects by sending high current on impulse to a heater ribbon, equipped on the surface of the heat-sealing blade, to generate heat that enables thermal-sealing through thermal conductivity. The section to be sealed is placed between the heat-sealing blades, pressed and thermal-fused when current and heat are delivered on impulse through the heater ribbon. After the current stops the seal remains under pressure to cool and to give it a clean finish.
(Source: The Hoso Times, published by Nippo Co., Ltd.)
Jan 28, 2013 | Office Equipment & Supplies
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products...
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Aug 04, 2010 | Gilmour Mfg Metal Impulse Yard Sprayer...
Paslode Impulse Framing Nailer won't operate
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
Exercise & Fitness Logo
237 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
