Question about Brother HL4150CDN Laser Printer
Brother hl-4150cdn keeps jamming
Every print is jamming at the rear
  • 33 Answers
SOURCE: brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Posted on Nov 02, 2007
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
SOURCE: Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Posted on Apr 23, 2010
How do I clean the printer? My pages have black spots
Black spots are toner accumulated at TONER COMPARTMENT , FUSER OR BOUTH. USE A VACUM CLEANNER PROTECT THE LASER GLASS W/ PAPER AND SPRAY AIR W/ AIR CAN. MUS BE CAREFULL!!!!!
Oct 11, 2014 | Brother Office Equipment & Supplies
White line down center of page
There is either paper dust or or dirty charger wires or something physically touching drum during copy cycle. Look for the obvious.
Feb 23, 2014 | Brother HL-4150CDN Laser Printer with...
Still having black spots even after cleaning drum. Could anyone tell me how to fix that?
Hi Brian,
Go To Below official Brother Printer Page For Your problem, White spots on black text and graphics or black spots appear Brother Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Dec 04, 2013 | Brother HL-4150CDN Laser Color Printer,...
Power surge knocked out power How do I get to the power source?
This problem can might involve in some internal circuit check up, if you are confident about your technical skills then download the service manual to check the power circuit thoroughly or else get it checked from some hardware shop.
Sep 30, 2013 | Brother HL-4150CDN Laser Printer with...
Product is Brother HL-4150CDN laser printer. The LCD display is saying Replace Toner (Back) I have 2 black toner carts available. One that I slightly used previously before swapping it out with a new one...
Had this same problem on the same printer. Here is the solution.
Open the front cover of the printer and press "Cancel" & "Secure". This will access a secret menu that will let you reset the toner counter. There are 12 settings in all (3 per color).
Two thumbs up going out to TonerHacker007 on the fixyourownprinter.com forums for this one.
Jul 30, 2011 | Brother HL4150CDN Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
Brother HL4150CDN Laser Printer Logo
21 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
