Question about Visual Land Prestige 7" Tablet Purple
Power pin not working
Charging pin is loose
    Problem Solver:
  • 10 Answers
These guys are very good with fixing USB ports www.nabilselectronics.com
Posted on May 09, 2014
If I reset my RCA tablet with a paperclip will I lose everything on it
try holding the volume up button and then power it on ( keeping the volume up button pressed in ) if you get a menu just click restart tablet. you will loose everything if you reset with pin but some tablets have a hard reboot option like i described but it wont delete anything
May 30, 2015 | Tablets & eReaders
Tablet won't charge
Check your charging pin. Is it loose? Is it moving or pushed backwards. The charging pins on most of the less expensive tablets are malfunctioning. 4 tablets I've recieved had terrible problem that way. Mostly unfixable, unless that's the problem and you know how the solder such things. Also try a new micro usb and a different electrical outlet, good luck!
Mar 04, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
My daughters tabeo charging port is loose and wont charge how do i fix it?
I would take it to a tech. before it gets more damage
Dec 17, 2014 | Toys R Us Tabeo
Mycharger on my samsung table 10.1 tab 2 won charge please help
The problem might be that your battery is too old. Rechargeable batteries have a limited number of charges that it can undergo.. usually between 300 and 500, before it starts to not hold much power anymore.. If it's not the battery,
I suggest you test the charger.
if you have a multimeter/voltmeter, unplug the charger from the wall socket and tablet. Set multimeter to measure Resistance/Ohms.. Touch one end of your meter cable to one of the charger pins(that you would otherwise stick into the wall socket) & the other end to the end you otherwise stick into the tablet.. all you're looking for is 'some' measurement... if you get a reading, test the other pin (wall socket end of the charger) .. if you get a reading again, then your charger should be fine.
Next look at your tablet, where you stick the charger into.. does anything seem loose/out of place? if no.. call the shop you bought it from an ask for assistance over the phone (typically shops offer advice freely over the phone)
Nov 12, 2014 | Tablets & eReaders
I have an XO tablet for my kids but they've broken the charging port... is there anyway to replace the charging port myself
Hi Johhnie,
To repair a charging port you will need the following:
  • fine tip soldering iron (Weller 15 watt)
  • Dremel tool with cut off wheel
  • De-soldering Braid
  • Torx T5 screwdriver
  • small flat bladed screwdriver (optional)
  • Diagonal cutters
  • small hemostat or fine tweezers
  • Panavise, helping hands or similar bench top holding device.
Take off the back cover and remove the battery.
Next, whip out that Torx T5 and remove the screws holding the phone together. On this one, there were only four to remove.
With the screws out, gently pull the phone apart. The lower half of this Motorola clips together, so I gently worked around the edges with a small flat screwdriver until it came apart.
The SIM card board easily separates from the phone via the flat SMD connector. Just gently apply pressure near the connector and it comes right off.
Next, the flat ribbon cable needs to be detached in the same manner, and the main PC board removed from the phone. It should pull right out once the cable is disconnected.
As you disassemble the phone, put each of the pieces into a parts bin. Any sort of container will do, but I'd avoid a static generating plastic Tupperware container.
Carefully place the board in your clamp/Panavise/whatever - I had to line up the buttons with the slots in the vise, or I probably would have damaged them when I clamped the board
You'll need a new connector before you can fix anything.
In order to check the condition of the pins, clip the two tabs that hold the rear shielding on to the connector with a pair of diagonal cutters.
With the rear shield removed, we can access the rear pins - Unlike the front, everything looks pretty good. The advantage of surface mount parts is that they don't require much solder to hold together. Unfortunately, when you're replacing a surface mount part, a small amount of solder can keep you from removing the part without damaging the board.
To keep from burning this foam seal, peel it back and stick it off to the side.
Enter the rotary tool. Sliced the top off of the connector by cutting the sides lengthwise.
Next, cut across the center of the connector. The bent pins should be gently cut loose and the upper half of the plastic connector will probably fall apart. The shielding on the sides should be cut to allow each leg to be removed individually. (Be careful not to cut the PC board below!)
Working from one side to the other, heat up the solder pad on each pin. Then use some tweezers to grip each pin of the connector. (I used a small pair of alligator forceps) If the solder is hot enough, the surface mount pin should come loose with little to no force. It's vitally important to be as gentle as possible with each one. The solder pads on the PC board are very delicate, and easy to pull up if you're not careful. Unfortunately, overheating the pads can also cause them to pull up. So be quick about it!
With the delicate pins out of the way, I carefully cut apart the remaining plastic and removed it.
Finally, the remaining legs of the shielding were heated and removed from the board.
After the new port is aligned (double check the pins in the rear!) solder one of the shielding legs to the board. Double check the pin alignment again, and solder the other legs. Now the port should be solidly mounted.
Next, the pins on the new port need to be soldered. The super fine tip on my 15 watt Weller pencil made this easy. Alternatively, you can use a wider tip to solder things and go back over the pins with de-soldering braid to remove any solder bridges. If you forgot to remove the rear shield, you'll have one hell of a time soldering the pins. On this particular phone, the metal shielding behind the port made it impossible to access the pins without removing the rear shielding.
Regards
Martin
Jun 18, 2014 | Tablets & eReaders
Huawei s7-931u not power
Use a pin and press the reset hole on the back of the tablet.
If that doesnt work:-
Check your charger it may not be working - plug into a usb socket and let it charge from the computer.
Apr 05, 2014 | Huawei Tablets & eReaders
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Aug 09, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Ainol Novo 10 Hero Tablet won't turn on
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Dec 26, 2012 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Visual Land Prestige 7" Tablet Purple Logo
105 people viewed this question
Top Visual Land Tablets & eReaders Experts
Steve Mason
alex metro
alex metro
Lawrence Oravetz
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
