Question about Tablets & eReaders
Flypad ultra tablet pc
Damaged charging pin
Why won't my tablet turn on?
Damaged charger? Damaged battery? Damaged Screen?
Try charging it for 8 hours. Stick a pin or paperclip in the rest hole and hold your breath.
Dec 11, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My prestige elite 7 tablet will not charge even when plugged into pc through usb chord.
Try using a USB charging cable that plugs into a wall socket (via adapter), rather than using a cable plugged into the computer. Computer USB sockets sometimes have lower power ratings and are insufficient to charge tablets.
(It is not clear if you have successfully charged on computer before or not). Also just try a new cable if you have not as they can become damaged (get one with a decent make - sometimes the very cheap cables and charges are poor quality and do not work well)
If none of that helps / you have tried it all please reply and I will try to help further.
Dec 07, 2014 | Tablets & eReaders
Tablet not charging
Check whether Charger is connected well and is functioning well.
If Charger is perfect.. check for lose contact of charger pin in Tablet Charging Port.
If both things well.. contact service centre..
Aug 17, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
How do I get Tablet fix it will not charge?
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
Jan 09, 2014 | Azpen A9 Android Tablet
My Kocaso M1062 will not take a charge and says connect charger.
The power Cell (Battery) no longer accepts a charge. The exception is if the AC/DC charging adapter has failed. See if you have a similar power charger around the house. Look for the same type of male pin and proper DC or AC Voltage plus Amps as listed on the current Tablet Charger. Never leave chargers in the electrical outlet alone as they can be damaged by surge power. Try another charger and if that fails also, the power cell in the tablet needs replacing.
Dec 19, 2013 | Kocaso Tablets & eReaders
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
Damaged pin on fairly new tablet, it will charge very slowly, poor contact. how to repair, manufacture will not. it works great when chatged.
Maybe u should just sell it and just use the money u got for it and just add more to it and get another one. Good Luck!!!
Nov 15, 2013 | Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Q1 ultra not booting
Fixed it. Opened the back cover and reinserted the memory.and it bootedup. So I guess memory got loose.
Feb 17, 2009 | Samsung Q1 Ultra Tablet PC
My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Jul 28, 2008 | Gateway M275 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
