Question about HP 32sII Calculator
Enter degrees minutes and seconds on hp32s
I want to add angles in degrees minutes and seconds on an HP 32s rpn calculator. How do I do it?
4 Suggested Answers
Mikey1963
  • 27 Answers
SOURCE: standard devation
Try this link if you haven't already, only found 33s myself but haven't had much time to look around the links.
http://www.shopping.hp.com/webapp/shopping/can.do?landing=calculator&category=Scientific&catLevel=1&storeName=storefronts
Posted on Jun 17, 2008
  • 7993 Answers
SOURCE: I NEED PROGRAM
Here is the program taken from the manual for the calculator. Key it in and use.
6f5d0fa.jpg The program requires 94 bytes.
Hope it helps.
Posted on Oct 01, 2009
  • 7993 Answers
SOURCE: where can I get calculator repaired?
Contact this repair shop in Pennsylvania. On the list you will find indication about the cost.
Posted on Jan 01, 2010
Hp 32sII enter degrees minutes seconds
According to the "HP 32SII RPN Scientific Calculator Owner's Manual" (at the link below), you just need to treat degrees, minutes, and seconds conversions as hours, minutes, and seconds. Use the left-shift and right-shift keys together with the 5 key to convert to decimal-fraction form (D.d format) and to minutes-seconds form (DD.MMSSss), respectively.
http://www.hp.com/ctg/Manual/bpia5305.pdf
See pages 4-9 and 4-10.
hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-0.jpg hp-32sii-enter-degrees-minutes-seconds-5ti10bsvdnjq4loa1azfxjeu-1-1.jpg
Apr 09, 2014 | HP 32sII Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How can I find sin 45degrees 20 minutes using a fx-9750G PLUS calculator?
The problem is not finding the sine of the angle but expressing the angle in Degree Minutes Seconds instead of decimal degrees.
  1. In RUN screen press [SIN] function key
  2. Press [OPTN]
  3. Press [F6] to get to next page of menus.
  4. Press [F5:Angl]
  5. Enter 45 and press [F4: degree ' "]
  6. Enter 20 and press [F4: degree ' "]
  7. If you have seconds to enter, type in value and press [F4:degree ' "]
  8. Press [EXE] to get your result.
This procedure will give you the sine regardless of the angle unit the calculator is configured for.
Sep 30, 2010 | Casio FX-9750GPlus Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [2nd][+] (") to access the double quotation mark
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
Converting degrees and minutes and seconds to radians
With the TI8x/TI8xPlus you can enter an angle in degrees (Angle mode must be set to degrees) and convert it into DMS representation the following way. Exemple
18.675 [2nd][ANGLE][4] [ENTER] gives 18deg 40' 30''
If Angle [MODE] is set to degrees you can enter a number in radians and convert it into degrees. Exemple How many degrees are ther in 1rad ?
[1][2nd][ANGLE][3] display 1 with a small r as superscrit. Pressing [ENTER] yields 57.29577951
To convert 1rad into DMS, takes a little effort but can be done: you have
to convert radians to degrees and the result [ANS] into DMS.
You cannot use an angle written in DMS in any calculation.
But if you want to convert an angle from degrees to radians enter your number and divide by 57.29577951
Hope it helps
Sep 02, 2009 | Texas Instruments TI-84 Plus Calculator
Minutes
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
How do you enter an angle in degrees, minutes and seconds on the HP 33s ?
Enter than angle as 32.2010 then press left-shift [->HR] to convert to decimal degrees.
The ->HR function (and the companion ->H.MS are for working in hours-minutes-seconds, but they work just as well for degrees-minutes-seconds.
Oct 21, 2007 | HP 33s Calculator
HP 32sII Calculator Logo
22 people viewed this question
Seeker5211
Seeker5211
