Question about Xerox Workcentre 7535/P 7535P Color Advanced Multifunction Copier, Printer,
Xerox 7535 offline
How can I get this printer to show online? We have Xerox maintenance to look at it, but still offline Shows offline in the Print server also No one able to use it
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
  • 2072 Answers
SOURCE: xerox 3545 offline
Did you set the IP address to Manual ( Static) to set up a permanant IP address? If you left it on auto and DHCP settings wrong, it will search and reset the IP address. Run a configuration report and check to see if you IP address has changed, I bet it has.
Posted on Jan 22, 2009
exil0r
  • 118 Answers
SOURCE: printer offline
Open system properties (my computer --> right click --> properties) go to hardware tab and click device manager. expand the usb controller and see if there are usb printing support, if exist go to control panel --> printer and faxes. right click in your printer icon and select use printer online.
if you don't find usb printing support in device manager the problem is with your usb connector. try to change it and make sure the printer power is pugged correctly.
Posted on Mar 12, 2009
  • 2072 Answers
SOURCE: need to print but the maintenance kit is late
No. That maintenance kit has a chip attached to it. That will reset the machine, It is just a white roll impregnated with silicon to clean and maintain the surface on the drum.
It will take replacement of the kit to reset the machine.
Posted on Nov 04, 2009
  • 186 Answers
SOURCE: Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Posted on Feb 18, 2010
Ho to fix ? My xerox workcenter 7535 stuck at boot process
reload software using the altboot method and if it fails u will have to clone your hard disk from a working 7535
Jul 21, 2016 | Xerox Office Equipment & Supplies
I have a Xerox 7142 wide format printer. It gives me this error on the machine. How do I fix error - E016 CPUErr [35]
Looks as if the series of E016 CPUErr point to a problem with the main board and may need to have a replacement, so would suggest a maintenance call out. Sorry.
Feb 26, 2015 | Xerox Office Equipment & Supplies
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Mar 04, 2014 | Xerox WorkCentre 4150 Black and White...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox 7535 Work Center makes buzzing noise when idle.
Your machine should be looked at by a certified Xerox Technician. Please call for service.
Nov 28, 2013 | Office Equipment & Supplies
Printer offline
Mar 12, 2009 | Xerox DocuColor 12 Printer
Xerox Workcentre 7535/P 7535P Color Advanced Multifunction Copier, Printer, Logo
443 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
