Question about Sony PlayStation Video Game Consoles & Games
PS3 MK4 POWER SUPPLY - PlayStation Sony Video Game Consoles & Games
Can the power supply on a PS3 be tested
Yes, best thing to do would be to go to a buyback games or check locally for information on testing a PS3 power supply.. Or you can google: How to test a PS3 power supply. good luck.
May 07, 2014 | Sony Official Playstaton 3 PS3 Power...
PS3 boot up issue!
you have a power supply OCP fault.
The power supply needs to be replaced or tweaked. There is a variable resistor inside the power supply that needs to be adjusted.
Yopu PS3 is tripping the Over Current Protection fault circuit. Common problem
Jun 28, 2013 | Video Game Consoles & Games
Golf mk4, 1.6 akl engine
Fuel supply to filter, filter to pump, pump to regulator, regulator to engine. you good?
Aug 27, 2012 | 2002 Volkswagen Golf
Ps3 no power no lights cord is fine switch is fine HELP!!!!
Its possible that the power supply isn't putting out all the voltages required for the ps3 to turn on. Best way to verify it is if you had another known good working power supply to swap it with. If you can swap the power supply and get the ps3 to turn on then you know your power supply is bad. If it still gives you the same problem after swapping then the main board is bad. I believe the ground should show 5 volts. if the 5 volts isn't present then the power supply is definitely bad.
May 06, 2009 | Sony Playstation 3 (PS3) Console
Japanese ps3 power supply
US and Japanese power supplies are the same. The 60GB PS3's run hotter than any other models. I've never seen a power supply get hot, but if it is then it's probably a good idea to swap it since heat is the number one 60GB killer.
I just created a blog that has a ton of usefull PS3 info and tips. Please check it out here:
http://rescuetechla.blogspot.com/
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
Is it difficult to replace the power supply in a PS3?
I Definitely Suggest you just buy a new power supply,,,, If your power supply fails, you can have multiple issues with your ps3... Being as expensive as they are... i would just say your best bet is to buy a new power supply... As for where to buy... Definately ebay... way cheaper!... make sure you check people's ratings before buying.... If you dont have access to ebay, then i suggest hitting up a electronics store that sells ps3's... if anything it can be ordered in... :D Good luck... Please rate! :)
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power supply
Check the power suply output voltage and freqwency. Then get the same info from a US power supply. If it matches shouldn't be an issue. Yet I think the best is just to get a transformer from a european store from 220 to 110. It may be cheaper that a power supply. If still interested in a US power supply I have one available. My email is bubulica2000@yahoo.com.
Thanks
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power supply cost?
nutterbutter
In regards to looking for PS3 powersupplies you have 2 options. You can do a search through Ebay and/or you can do some searches on the Internet.
I got one the other day for $35 after shipping.
Here is some links that I ran a search on. Note PS3 is also a term used in computer powersupplies so you will get some hits on them as well.
http://shop.ebay.com/items/ps3%20power%20supply?_dmd=1&_sop=12&tt_encode=raw&crlp=1652236613_9405&keyword=ps3+power+supply
http://www.google.com/search?hl=en&q=ps3+power+supply&aq=4&oq=ps3+po
Let me know if you have any more questions and/or problems.
Issken
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power supply
I can sell you a power supply if interested but if you get a red light the power supply is most likely still good. You may need a new motherboard.
Aug 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power supply to console
BUT A NEW POWER SUPPLY OFF OF EBAY !!!!!! IT WILL COST YOU AT MOST 47.98 DO NOT PAY MORE THEN THAT .......!! TRUST ME DO NOT PAY SONY NOTHING 150 DOLLARS IS OUTRAGEOUS WHEN I KNOW FOR A FACT ALL THEY DO IS SWITCH OUT THE POWER SUPPLY UNIT ..THAT IS ALL THEY DO .....!!!!.....I HAD THE SAME PROBLEM ......I WAS PLAYING COD WORLD AT WAR AND THEN OUT OF NOWHERE IT JUST SHUT DOWN COMPLETELY ,..WHEN I TRIED TO TURN IT ON IT SHOWED A GREEN LIGHT FOLLOWED BY AN AMBER LIGHT QUICKLY TURNING TO A FLASHING RED ........I THOUGHT IT WAS AN OVERHEATING ISSUE BUT MY AMBER LIGHT SHOWING INDICATED A HARDWARE ISSUE SO I TOOK A CHANCE AND BOUGHT A POWER SUPPLY UNIT OFF OF EBAY AND RECEIVED IT WITHIN A WEEK .......IT BOOTED UP PERFECTLY FINE TRUST ME ...FOR GET SONY AND TRYING TO DO ALL THAT FANCY TRANSISTOR SWAPPING GEEK TALK BULL......JUST SWAP YOUR POWER SUPPLY UNIT AND THATS IT ...YOUR PS3 IS BACK ONLINE !!!!!!!!!!.....THATS IT BOTTOM LINE !!!!!!.....TAKE MY ADVICE OR LEAVE IT I DON'T CARE BUT I FIGURED I SHARE THIS WITH YOU GUYS SINCE I WENT CRAZY RESEARCHING WHY THIS HAPPENED AND I BASICALLY PUT COMMON SENSE INTO THE EQUATION TOOK A CHANCE AND BAMMMM!!!!! BABY I FIXED IT LOL..LOL...HOW ABOUT THAT ..FOR ALL YOU SO CALLED KNOW IT ALL PEOPLE OUT THER ..LOL..LOL.!!!!!...DAMN GEEKS TURNING THINGS INTO ROCKET SCIENCE ALL THE TIME .....LOL...........EBAY OR ANY OTHER PLACE YOU CAN GET YOUR HANDS ON ONE OK .........THANK ME LATER OK ..LOL.....TAKE CARE ..
Nov 04, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
15 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
