Question about Ricoh Aficio CL3500N Laser Printer
Pjl tray selection - Ricoh Aficio CL3500N Laser Printer
Malfunctioning. wont print documents or pictures. Just some kind of jumbo mumbo. like; @PJL SET REPRINT=OFF, @PJL SET HOLD=OFF....etc.
That "mumbo-jumbo" is the printer code. It may well be that you either have the wrong driver installed for the printer and it is misinterpreting the code, or the driver may be corrupt and needs to be reloaded.
Nov 04, 2015 | Epson WorkForce Pro WF-4630 Wireless Color...
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
Does ExtentNet 100x support Zebra printer language ZPL2?
It doesn't support it directly, but it shouldn't prevent it from working. However it might be sending extraneous PJL commands between print jobs (example @PJL -12345X) which could mess up a label. ZPL is basically ASCII, the ExtendNet shouldn't prevent ASCII delivery.
Feb 14, 2011 | Extended Systems ExtendNet 100X Print...
How to change the serial number in hp laserjet 3055n after replace the foprmatter board.
I dont have the answer; however the closest I could find in teh 3055 service guide was the following statement:
"Printer job language (PJL) software commands Many PJL scripts are available for restoring parameters such as paper size and page counts after the formatter has been replaced. For comprehensive instructions, see the Printer Job Language Technical Manual and the Printer Job Language Technical Manual Addendum"
I do not have those two manuals but it would seem that is the direction you need to head in order to solve this issue. Many of the HP laserjet's have an easier method than using PJL commands, however this model does not provide such ease of use.
Aug 29, 2009 | HP LaserJet 3055 All-In-One Printer
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
LaerJet 5p Extra page prints with code
check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Oct 28, 2008 | HP LaserJet 5p Printer
Pgm to staple with a Canon ImageRunner 5000
Canon handles it as PJL comments.
Google the string "PJL COMMENT CANPJL"
Aug 25, 2008 | Canon imageRUNNER 5570 Copier
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
Apr 22, 2008 | Lexmark T642 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
