Error 010-333 The machine printed only 2 sheets after changing it with another fuser unit from a 7132 xerox printer
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
Posted on Jan 13, 2010
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
After replacing fuser upper roller machine shows error code 010-327.after resetting 3 to 4 times then the machine comes in ready
That error signifies that the fuser is not heating up, it could be the lamp or the thermistor, check your connections and lamp continuity.
Jan 19, 2016 | Xerox Workcentre 5225 / Copier, With...
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
How do i get get rid of 010-330 code on a xerox 7132
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info. Solutions for : Fault Code 010-330: The Fuser Motor is Not Rotating at the Specified SpeedMessage Related Fault Code: 010-330 Solutions ranked by relevance:
  1. Power the Machine Off and On
  2. Remove and Re-install the Fuser
  3. Replace the Fuser
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=468,E=0000000000016144604,K=4237,Sxi=2,Case=obj(3468)
Oct 07, 2014 | Xerox Work center 7132 copiers
Xerox workcentre 7132 error code e10-333
  • Problem occured by fuser unit,
  • Check the voltage supplies to the machine and to and from the LVPS
  • Check the Indoor Temperature.
pls change new fuser unit
Jan 17, 2014 | Audio Players & Recorders
Printing dulipcates on xerox 7132 when multi printing
In this case what i would Request u to do is. Goto Control Panel goto Printers folder. There u will see the Printer Icon. Just right click on the Printer Icon and click on Properties.Now click on Advanced and goto Print Processor.Change it to Printer Name and Win print Raw.Click on Apply click ok now try to Print.
Good Luck!!!!
Apr 18, 2013 | Xerox WorkCentre 7132 PCL 6
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
The printing is ok on about 2 thirds of the sheet but each printed sheet has a black line about 2 " wide all the way down the sheet we have a xerox xc351 photo copier we have tried a new toner.
I'm not familiar with the Xerox, but it sounds like you've probably got a bad drim or drum blade, which, I think, comes as a whole PCU or photoconductor unit.There's other things such as fuser rollers, could be dirty laser, etc.
Jul 16, 2009 | Xerox Office Equipment & Supplies
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
13 people viewed this question
jasbo
jasbo
