Question about Toshiba TE2100 Notebook
  • 1,006 Answers
Posted on Oct 27, 2007
0 characters
3 Points
I recently replaced my old Belkin N150 Wireless Router with a new Cisco E3200 Wireless Router. After doing so, all of my wireless devices work (9 total) EXCEPT for my (2) Acer Aspire One Netbooks. The...
Remove and recreate the wireless network connection
  1. Click on Start, and then Control Panel
  2. Double click on Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network that you want to connect to, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the wireless network adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  1. Click on Start, Settings, Control Panel
  2. Double click Network Connections
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice.
Sep 23, 2011 | Acer Aspire 5100 Notebook
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
Computer connects very quickly (wired connection), but after about one minute computer goes off-line. message says 'problem with one or more of your network adaptars" however, when i connect to a...
Laptops have two adapters that work independently so even if your wireless works your lan may not. For your lan, (wired), network adapter first try to install the latest updated driver. Go into device manager ( right click my computer and choose/ properties/ hardware/ device manager ) scroll down to your network adapters and look at the properties/ driver and note the driver date and version. Next go to your laptop manufacturer and search your model under downloads to find the latest offered driver. If it is newer than the one installed on your computer go ahead and install it and that should fix your problem. If that doesn't work post back here with more information and we can go deeper into the problem.
Apr 07, 2011 | PC Laptops
I cannot connect to the internet wirelessly.
is your driver installed well? try to activated your wireless open your device manager find some wireless device there if you cant find wireless device (wireless lan) than you have to cee is the device installed well on your netbook
Jan 16, 2011 | Acer Aspire One AOA150-1504 Netbook
Please help me get my wireless settings
If you have windows XP on the laptop then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista on the laptop:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa
rating. If you cannot rate this post with the highest rating, then please
comment to this post and I will try to help you further.
Aug 30, 2009 | Acer Aspire 3000 Notebook
My laptop used to connect to the wireless connection , but one day it stopped working and now i can only connect to internet using a lan cable
go into the device manager and uninstall the wireless adapter. Then click scan for hardware changes and let windows resinstall it. It sounds like a corrupt driver. Before doing so make sure you didnt hit the wireless button that shuts off the connection on the computer. :)
May 26, 2009 | HP Pavilion Tablet Notebook
Wireless connection problem with Medion MIM 2120
hi..go and try to find the (Control Panel) then double click the icon of name is (Network Connections) then find the wireless LAN connection..if you have wireless connection u need configuration..if not no have wireless connection you need re-install the LAN card driver..Thanks and good luck..^_^
Feb 01, 2009 | Medion md40298 Notebook
I restored my hp notebook and now cant connect to the internet
You have to set your wireless connection again.
Select your wireless network, insert you key or password (if any) and connect
Oct 06, 2008 | HP Pavilion dv6000z Notebook
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Networking Problem
By local network do you mean using a wired connection or a wireless connection? I gather you mean with a wire.
The following link is to a PDF page listing the lan drivers from acer for an Aspire 3680 --
Drivers Link
The second and third entries on the list both appear to be wireless adapter drivers for built-in hardware (atheros or broadcom). Are you sure the driver you have loaded is the correct driver?
To determine which if the two may be suitable for your machine try the following
Click Start and right mouse click My Computer and select properties
Select the general tab and click on device manager
find your wireless adapter probably preceded by a yellow question mark (?)
double click on the wireless adapter entry
get the name at the top of the general tab and
the click the details tab and record the
device instance id value
Report what you found back here in a comment.
Hopefully the name will contain atheros or broadcom of not I hope I can lookup the device instance id string to determine the manufacturer of the wireless adapter.
Dec 11, 2007 | Acer Aspire 3680 Laptop
Toshiba TE2100 Notebook Logo
57 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
