Question about ASUS RTG32 Router
The router configuration page does not load correctly.i have to reload the page several times to get the configuration page.Many times when i click on apply settings,it do not work.Please can anyone h
The router is working fine but when i want to change my password or something other.I have to reload the page about a 100 times.
  • 3 more comments
  • Panagiotis Tabakis
    Panagiotis Tabakis Feb 12, 2014
    Hi Sanket Gupta, I want to help you with your problem, but I need more information from you. Do you try to connect to the router via wifi? If so, what is the strength of the signal?
  • Sanket Gupta
    Sanket Gupta Feb 12, 2014
    yes i connect the router to m pc via wifi.The signal strength is also very good.
    I suggest you go herehttp://www.pcwintech.com/showimage?file=... and comment the error logs so we can check if there is a router error slowing it down
  • Sanket Gupta
    Sanket Gupta Feb 14, 2014
    thnx but i think that the router just needed a firmware update. now it is working fine. thnx for help
    Panagiotis Tabakis Feb 15, 2014
    Ok i am posting it as a solution so others can find help on the issue
  • 67 Answers
How to upgrade firmware on ASUS RTG32:
  1. Go here ASUSTeK Computer Inc Support Search
  2. Select your router (by clicking Download)
  3. Select your OS
  4. Click on Firmware and download the one that suits your country.
  5. Click on Ultilities and select the one that suits your country.
  • Global is the direct link.
  • Global (DLM) uses your browser's Download Manager.
Launch the Utility and follow the on-screen instructions.
Posted on Feb 15, 2014
3 Suggested Answers
serra_baby
  • 144 Answers
SOURCE: Can´t access 192.168.1.1 (router admin page)
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Posted on May 06, 2008
SOURCE: Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Posted on Nov 20, 2008
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
I'm trying to configure my linksys router but the
Be sure you are connected by wire into your router.
Also, look in your system folder to make sure that the hardware for your ethernet card is installed and running.
Be sure that 192.168.1.1 is the right address too. I have a router that is 192.168.1.254 and another that is 192.168.1.2.
Jan 04, 2010 | Linksys Wireless-G WRT54G Router
I am trying to use the usb adaptor with a compaq presario computer with windows XP, and a router that i got with AT&T. i remember it working once, but i cant remember how to set it up. everytime i...
Te first thing you should do is remove all power from the AT&T devices (modem, router, etc) for at least ten minutes. This will do several important things.
1. It will force your ISP (AT&T) to drop all connections to and from their router to the DSL modem.
2. It will force your ISP (AT&T) to re-establish the connection to the DSL modem.
3. It will force the DSL modem to clear all RAM and reload its default configuration when power is re-applied.
4. It will force the wireless router to clear all RAM and reload its configuration information when power is restored.
The 10 minutes is not arbitrary, some Motorola DSL modems supplied by AT&T have a specified 8 minute memory backup capability.
Nov 25, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Configuration page doesn't load
1. can you ping the router? go star>run>cmd and type ping 192.168.0.50
if the ping times out or says it's unreachable, check your network connections (cables are fully seated and there leds are blinking properly)
2. try to type 192.168.0.50 on the address bar and hit enter, did you change the ip address on the router before?? if you did and can't remember what ip address you gave to it you may need to reset your router.
3. try the same ip address in another browser (IE, chrome, firefox), Make sure your browser has Java, JavaScript, or ActiveX enabled. If you are using Internet Explorer, click Refresh to be sure the Java applet is loaded.
4. are you using the right the correct user name and password? enter 'admin' (lower case) and hit enter or the password you may have configured, if you can't remember what that was reset your router.
you router's manual can be downloaded from here
good luck
Nov 22, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Cannot connect the the Zyxel page to configure my Embarq router.
you can check the router ip address by going to network connections in control panel and then, right click on connection icon>status, then support tab, there will be the ip address of your pc and the default gateway address which will be your routers address.
If you still cannot get into the router, there will be a hard reset button on the underside or rear of the unit.
Aug 18, 2008 | Zyxel Prestige 660H Router
Program for belkin router
you don't require the disk...
co0nnect your belkin router with ethernet cable into the comp...
open internet explorer type an address as 192.168.2.1 it will take you to router config page..it will ask for a password leave it blank
click submit
click the Wizard link on the top menu bar.
For a UK ADSL connection, you will need to select PPPoA (Routing mode, for multiple PCs) even if you are only going to connect a single computer, then click the next button.
The next step is to enter your username and password that your service provider has provided you with. To try and ensure the password is entered correctly it must be entered twice. The VPI/VCI values of 0/38 are the correct ones for a BT Wholesale ADSL line. If you are using another telephone provider check the settings required. Click next again to continue to the next phase in the wizard.
This screen tells you what your Internet IP address is (the WAN IP), and you will note that the menu bar at the top of the page now shows the Internet Status as connected. For the review, there is really one bit of configuration left to do. During the course of reviewing hardware we tend to swap kit in and out several times, we generally prefer to run the routers on the same IP address (192.168.0.1). This is easily accomplished by clicking the LAN Settings link on the left hand menu of the Belkins web setup and altering the routers IP address.
The router is clever enough to alter the DHCP server IP ranges to match the new LAN IP address of the router. Once the changes were applied it took around a minute for the router to restart, during which time the wireless signal dropped, but once this reconnected the PC was assigned an IP address in the new range of 192.168.0.x.
Feb 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
I have to repair my connection to get internet
Are you running a virus scanner or internet security software?
Is it active and has it been updated recently?
Do you perform periodic full scan of your systems and are they clean?
Do you run any apyware packages?
Are they active and have they been updated lately?
Do you perform periodic scans with them and is your system clean?
Not all virus scanners, etc catch all problems. Some catch different items.
Consider using free online services from some of the security vendors to double check your product. Several to consider
Trend Micro
Fsecure (www.fsecure.com and search for online scanner)
Symantec
Consider free spyware software for additional checks if you have not choosen to purchase a product to do this.
Lavasoft
Spybot
Clean up the issues found and see if the problems are eliminated.
Using the following instructions from the zonet website to get your IP address will also reveal your router's address in the default gateway entry (assuming your computer receives it's IP information via DHCP from the router or has been staticslly configured correctly). This will be the value you utilize instead of 192.168.1.1 to access the router's configuration.
spacer.gif Q: How can I find the IP address of my computer? spacer.gif A: Windows 95, 98, and ME:
Click on Start.
Then click on Run.
The Run Dialogue Box will appear. Type "winipcfg" in the window as shown then click OK.
The IP Configuration window will appear, displaying your Ethernet Adapter Information.
Select your adapter from the drop down menu.
If you do not see your adapter in the drop down menu, your adapter is not properly installed.
After selecting your adapter, it will display your IP address, subnet mask, and default gateway.
Click OK to close the IP Configuration window.
Windows 2000 and XP:
Click on Start and select Run.
Type cmd then click OK.
From the Command Prompt, enter ipconfig. It will return your IP address, subnet mask, and default gateway.
Type exit to close the command prompt.
Macintosh 8.x and 9.x:
Click on the Apple Menu>Control Panels>TCP/IP.
Select your Ethernet adapter from the Connect Via drop-down menu.
Under Setup, select Using DHCP Server from the Configure drop-down menu, if connecting to a router DHCP server. This is the most common setting when using a router. In this configuration, your computer will be automatically assigned an IP address by the router.
You must reboot your computer to "renew" your IP address.
Macintosh OS X:
Click on Apple Menu>System Preferences>Network>TCP/IP.
Linux:
At the command line type /sbin/ifconfig and you will get a listing of information. Your IP is shown after inet addr.
Dec 08, 2007 | Zonet ZSR0104CP (zsr0104cp) Router
Cisco router 2503
which router are you using?
Dec 03, 2007 | Cisco (WS-X3011) Router
ASUS RTG32 Router Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
