Question about Bullzip PDF Printer
Unable to select destination folder
When plotting from CAD via bullzip cannot select destination folder
    Scholar:
  • 139 Answers
Have you checked in your program settings to see if it has a default, or chose destination folder option?
Posted on Feb 12, 2014
Plan a route
For Garmin. Enter your final destination and select go. Select again "where to" and select new destination on route. Option of "New destination or add as via point" will be shown. Select as add as via point. Repeat as many time you want. Works only when "go" was selected - can not be pre programmed and saved for later use.
Apr 09, 2015 | GPS
I've been trying to use ocr on my Brother DCP-J315W and I get this error message: "Unable to write the file to Destination Folder. Please make sure that you have correct permissions to write to th
Where is the destination folder located is it windows .If Windows
Open file Explore (right click on Start icon select File explorer or explore) Right Click on Folder and check sharing permissions and allowed users.
Jan 03, 2015 | Brother DCP-J315W Inkjet Multifunction...
Unable to write the file to "Destination Folder"
A recent (Dec 2015) Windows 10 update seems to have removed the access required for the service account used by Brother to write to the hard drive. This fixed the scan function for me...
  1. Navigate to the directory where you write the files (C:\Users\YourID\Pictures\ControlCenter3)
  2. Right click on the Scan directory and open Properties.
  3. Click Security tab.
  4. Click Edit
  5. Select WMPNetworkSvc
  6. Allow Full Control
  7. Click OK
Nov 11, 2011 | Brother MFC-6890CDW Printer
How do I pull files off the harddrive?
if you want copy files to another destination
click start all programs accessories open windows explorer navigate to your destination folder/memory stick then go to the information you want to back up select the information right click select copy then back to destination folder/memory stick select then right click select paste
or select the imformation hold the cursor on then drag it to the destination folder/memory stick and drop it into it
or select the imformation right click and send to the destination folder/memory stick
hope this helps
Dec 05, 2010 | Computers & Internet
Transfer photos from laptop
hope this helps
Dec 05, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I need to download Acrobat distiller
try download u torrent on download.com, install it on your pc . and go to www.mininova.com, web site search for adobe pagemaker 4.x. Note: read comments before downloading and find the higher seeds.
Aug 12, 2009 | Adobe Photoshop 7.0 for PC
All leds light on panel
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Apr 27, 2009 | HP LaserJet 1300 Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=164&pID=31946
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
Information
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
Details
Click Update .
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
Computers & Internet Logo
61 people viewed this question
Top Bullzip Computers & Internet Experts
David Payne
David Payne
Are you a Bullzip Computer and Internet Expert? Answer questions, earn points and help others
