Question about Samsung Washing Machines
Filter wa75b7pt I would just like to know if there should be a lining or a spongy thing inside the filter of the top loader washing machine list above. Thanks Sam
    Prodigy:
    An expert who has answered 500 questions.
  • Samsung Expert
  • 517 Answers
That does not sound right
Posted on Feb 12, 2014
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
bozcro
  • 867 Answers
SOURCE: How to fix a machine that does not pump out the water
most likely pump is not working it is just behind where the drain pipe comes out of the machine.you can remove it to see if its not working . the impellor inside may be damaged
Posted on Jul 19, 2009
iwillfixforu
  • 619 Answers
SOURCE: please advise where the filter is located on our
Usually there is no filter to clean on the top loaders. It should be a self cleaning filter attached to the bottom of your spin basket, (what the clothes actually go into).
Posted on Feb 01, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
My washing machine type 580 is not washing clean. Leaving the cloths with lot of lint
clean the lint filter
you forgot to mention if it is a top loader ( inside the top of the agitator ) or if it is a front loader
Apr 14, 2015 | Washing Machines
Top loader not spinning
May have lost motor, belt, clutch, fuse, many different things can be the cause. Do you hear the motor running?
May 11, 2013 | Washing Machines
Suspected bearing failure
Go to www.repairclinic.com and enter WA75B7PT. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Samsung video showing disassembly. From that information, you may be able to solve your problem.
Feb 20, 2018 | Samsung Washing Machines
Door wont open after cycle has finished, have put on a different cycle didnt work either, pluged out maching for 30 min didnt work either, can you help
Hi.
The door does not open because there is water detected inside the machine. Water must be removed through the drain filter connected to drain pump.
Disconnect power.
If front loader remove the trim panel at the base of the machine. Top loader have access at the bottom or at the back.
Locate the drain filter access at one side.
Remove drain filter cap.
Collect water using containers (have them ready, a lot of water will flow out).
Put back cap and trim and reapply power.
Emptying water from drain lines is usually enough to unlock the door. If that does not work, then the door is opened reaching back side of the door latch (from inside the washer's cabinet). Access is from top, after removing panel, or from bottom. Some front loader has an emergency unlock cord inside that can be reached undoing completely the drain filter. The procedure requires disassembling and should be done by a technician.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Washing Machines
How do you take out the drum of a samsung Wa75b7pt top loader washing machine i want to clean it
Do not take drum out.
Run a wash without clothes in and put a mild bleach solution inside.
Feb 07, 2011 | Samsung Washing Machines
Jul 19, 2009 | Washing Machines
Bissell Powerforce bagless 6594 W filter cleaning and reassembly
the sponge filter goes around the plastic part with tons of vertical slits on it
Aug 08, 2008 | Bissell 6594 PowerForce Bagless Upright...
Washing Machines Logo
42 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
