Question about Bullzip PDF Printer
Bullzip not allowing me to select file save destination folder
Get error message when trying to plot from cad to pdf/jpg/tiff through bullzip. can't select destination folder
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Error 1007: An error occured while running Ghostscript How do I print my file??
Looks like GhostScript is corrupted and needs to be re-installed. Go to http://www.ghostscript.com/download/gsdnld.html and choose the appropriate version of Windows. Reinstall it and this will re-align the missing files and links.
Apr 10, 2015 | Bullzip PDF Printer
I've been trying to use ocr on my Brother DCP-J315W and I get this error message: "Unable to write the file to Destination Folder. Please make sure that you have correct permissions to write to th
Where is the destination folder located is it windows .If Windows
Open file Explore (right click on Start icon select File explorer or explore) Right Click on Folder and check sharing permissions and allowed users.
Jan 03, 2015 | Brother DCP-J315W Inkjet Multifunction...
I have a new laptop with Windows 8.1 (lucky me). I can't seem to get my Brother MFC 7860 DW to preform its normal scanning in pdf format.
you can try this solution : first scan to picture file and after convert it to a pdf file with a pdf printer like this one : http://www.bullzip.com/products/pdf/info.php
or try to find an update to the software (for the printer) at brother.com here :
http://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=mfc7860dw_all
hope it helps..... if not then return here ...
Jun 09, 2014 | Computers & Internet
Unable to select destination folder
Have you checked in your program settings to see if it has a default, or chose destination folder option?
Feb 12, 2014 | Bullzip PDF Printer
Problem scanning and saving pdf docs to desktop
I have the same problem. Try this:
If you set network path similar to: \\Server\Share you will receive an error. Try set path to folder located in network path eg: \\Server\Share\Folder
It works for me
Aug 29, 2012 | Office Equipment & Supplies
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
I receive an email from a friend in a jpg file but i can not open it,can yu help me please?
Presumably you mean the e-mail has a jpg attachment. What e-mail client do you use? If you can see a link towards the top of the e-mail for a file ending in .jpg right click and select save as or save file and then choose the preferred save destination. Some more information would be helpful though if this doesn't solve your problem. Do you get an error message? What can you see? Screen shots?
May 03, 2009 | Samsung Cell Phones
Computers & Internet Logo
27 people viewed this question
Top Bullzip Computers & Internet Experts
David Payne
David Payne
Are you a Bullzip Computer and Internet Expert? Answer questions, earn points and help others
