Question about Electric Cycling
Missing istruction manual for southern star electric scooter
Missing manual Do you know where I can get a manual for Freerider Kensington mobility scooter thanks Dianne
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
Missing Instruction Manual
Visit:WWW.ALLDATASHEET.COM & follow the info when you have typed in to search your needs.you will be able to view it as a pdf file & if im not mistaken you can print it off from there.Alternatively visit the main suppliers of your scooter,you should be able to purchase 1 online for a few pounds.
May 10, 2010 | Electric Mobility Mobility Electric Power...
I have a smart Meter supplied by Southern Electricity and have lost the instructions .I need to reset it .Has anyone a copy of the manual that they can e-mail.There is no manufacturers name on it either...
What you have is not a smart meter. You have an energy monitor. The instructions will be found by looking at energy monitor manufacturers websites. Which you have will be clear from the appearance despite the southern electric branding. owl is one brand.
Nov 24, 2009 | Kitchen Appliances - Others
Calibrating & Aligning the Meade 10" LX200 GPS Telescope in the Southern Hemisphere
  1. Do a Calibrate Sensors
  2. Do a Train Drive in RA and also DEC
This makes sure that the scope is calibrated properly.
  1. Do an AUTOMATIC ALIGN
  2. when asked to center star, look for the BRIGHTEST star that is close to the scopes field of view. It will be that star you need to used the arrow keys on to centre it in the scope eyepiece and press enter.
  3. This star can be as much as a HANDS distance away from the centre of view
  4. If you cannot identify the star it is asking you to use, press the SCROLL DOWN key to choose another star, keep doing this until you see a star you recognise.
That's it!
You can also hold down the MODE key for about 4 seconds and scroll through the scope info. Make sure you have the correct location coordinates ( Lat/Long) and the correct time set.
Select a bright object first such as a planet and GOTO it. Once you have manually centered it in the eyepiece, press ENTER and hold it for 6 seconds, the handset will say " Press ENTER to sync", press enter and you have updated the scope with the coordinates of that object.
Oct 20, 2008 | Meade LX200GPS Telescope
Cycling Logo
279 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
