Question about Yamaha 2005 RS Venture
How do you test a rectifier on a 1994 yamaha 340 ovation snowmobile ?
3 Suggested Answers
  • 63 Answers
SOURCE: my yamaha ovation snowmobile will idle but not
Hi, may have a safety switch under the seat? May be playing up, similar setup to yamaha pw50's, good luck :)
Posted on Jan 11, 2010
mycharmingli
  • 389 Answers
SOURCE: I'm looking for a downloadable
Contact Yamaha they will usually send you one for free.
Hope that helps if not let me know and will research further...
Posted on Nov 18, 2010
Snowmobile troubleshooting
One of (3) Possible Problems jumps into my mind
(a) Blocked High Speed Jets
(b) Primary Clutch Springs not correct
(c) Loss of Compression in the Engine (do a compression Test)
Jan 14, 2014 | Winter Sports
I have a 1979 yamaha 340 enticer.Recently it would not start, no spark. I tried new plugs and a new ignition coil but still no spark. Don't know what to do next.
Hi, Gmgroot and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1999 royal venture no spark limited knowledge need help
https://www.tradebit.com/filedetail.php/55384194-yamaha-1983-1988-enticer-excell-340-snowmobile-service
http://vintagesleds.com/library/manuals/yamaha/1980/ET340_80.pdf
http://www.gearhead.com/snowmobile/parts/oem/yamaha.html?aribrand=YAM&s2=snowmobile
Feb 04, 2011 | 2000 Yamaha Royal Star Venture
I'm looking for a downloadable service manual for a 1982 Yamaha Enticer 340 LT. It is a snowmobile. Thank you.
Nov 18, 2010 | Yamaha G5 Motorcycles
My yamaha ovation snowmobile will idle but not accelerate. feels like an electrical problem, some type of safety. any ideas?
Jan 11, 2010 | 1984 Yamaha XJ 400
Snowmobile yamaha enticer manual for carberater
why don't you just check the compression if it's low fix it check the carbs make sure it works and make sure you bearing are goo your clutch your vbelt your track and that you have a the boggy wheels on it
Jan 11, 2009 | Yamaha YHT-340 System
Yamaha 2005 RS Venture Logo
21 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Gene Tuck
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
