Question about Imperial Kitchen Ranges
Convection Oven Burner malfunction ;not fully lit. Oven not reaching proper temp.
bigg t
  • 640 Answers
SOURCE: Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
  • 146 Answers
SOURCE: maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Posted on Dec 29, 2007
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
docjohn174
  • 943 Answers
SOURCE: oven not heating properly
HI thanks for your question. the problem you have is with the bake igniter. a common problem with gas ovens the igniter should be replaced. thanks the appliance doc.
Posted on Oct 12, 2008
SOURCE: I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Posted on Dec 24, 2008
Oven doesn't get up to temp...stops at 245 burner is lit but not on high...it was suggested it might be the ignighter..is this possible in that the flames are still there???
I doubt its the igniter because the flames are lit. Its more likely the the thermostatic sensor is bad. Sometimes they can just be cleaned with a wire brush when they get full of grease. That sensor controls when the flames go on and off to keep the oven at the proper temp. A bad one could not let the oven get to the proper temp.
It could also be one of the burners isn't lit. Could be clogged up with grease. Pull the lower / broiler draw out and turn on the oven. Stoop down an look to see if all burners are lit. (Please don't touch unless you know what you are doing) but a cautious look might tell you a lot
Jul 14, 2016 | Kitchen Ranges
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Oven burner seems to have low flame
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Feb 09, 2009 | Jenn-Air JGS8850AD Gas Kitchen Range
Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 08, 2009 | Sharp R-1874 Convection/Microwave Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Maytag range shows fault code F14
Dec 21, 2007 | Kitchen Ranges
Kitchen Ranges Logo
16 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
