Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Hp cm6030 printer transfer kit level reset
Transfer unit
pdouglasss
  • 125 Answers
SOURCE: Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Posted on Jan 10, 2009
FixinFax
  • 3085 Answers
SOURCE: the left side of drums locked in the printer which is a Hp 5500
Pull the front door all the way down.
Posted on Aug 04, 2009
  • 81 Answers
SOURCE: how do i reset the transfer kit for HP LJ 4700
with the power on, press the down arrow button until the display reads " Configure Device" menu. Press the Select button and using the down arrow button, scroll through this menu until the display reads "Resets" and press the Select Button. Then press the down arrow button again until the screen reads "Reset Supplies" and press Select button. Once you get to this menu this is where you can reset the fuser and the Transfer belt count
Posted on Oct 13, 2009
  • 10406 Answers
SOURCE: I had to change the drumkit in my HP 4500. It says
Press the "menu" or "settings" or "advanced" button to view more menu-choices. Scroll through these menu-choices, to find that option.
Posted on Jan 14, 2010
  • 202 Answers
SOURCE: i have hp printer 4700 color laserjet .i installed
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
Posted on Apr 01, 2010
To printer 4025
you need to go where it says Service then input that code and scroll to reset the belt. ( this only needs to be reset in Service mode when changing before the counter says to.)
Dec 05, 2016 | HP LaserJet Office Equipment & Supplies
How do you reset an hp 3500 color laser jet printer?
follow the steps :
  1. Press MENU to enter the MENUS .
  2. Press c00047416.gif (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press c00047417.gif (Select) to select CONFIGURE DEVICE .
  4. Press c00047416.gif (Down arrow) to highlight RESETS .
  5. Press c00047417.gif (Select) to select RESETS .
  6. Press c00047416.gif (Down arrow) to highlight RESET SUPPLIES .
  7. Press c00047417.gif (Select) to select RESET SUPPLIES .
  8. Press c00047416.gif (Down arrow) to highlight NEW TRANSFER KIT .
  9. Press c00047417.gif (Select) to select NEW TRANSFER KIT .
  10. Press c00047416.gif (Down arrow) to highlight YES .
  11. Press c00047417.gif (Select) to select YES . The transfer unit count is reset and the printer is ready to use.
Mohamed Hejazi
Afaqnama-LIbya
ipg@hplibya.com
Feb 27, 2013 | HP Color LaserJet 3500 Printer
My 4700 hp printer is double printing and giving a replace transfer kit notice
This means you'll have to replace the transfer kit because it is "end of live". This also causes the printing problems. The transfer unit is the big black unit you'll find when you open the front cover.
Jul 29, 2010 | HP LaserJet 4700 Printer
The printer doesn't recognise a new transfer kit
To reset the transfer unit count, do the following:
  1. Press the green tick to enter the MENUS.
  2. Press the down arrow to highlight CONFIGURE DEVICE.
  3. Press green tick to select CONFIGURE DEVICE.
  4. Press down arrow to highlight RESETS.
  5. Press green tick to select RESETS.
  6. Press down arrow to highlight RESET SUPPLIES.
  7. Press green tick to select RESET SUPPLIES.
  8. Press down arrow to highlight NEW TRANSFER KIT.
  9. Press green tick to select NEW TRANSFER KIT.
  10. Press down arrow to highlight YES.
  11. Press green tick to reset the transfer unit count.
Jun 21, 2010 | HP LaserJet 4650n Printer
How do i reset the transfer kit for HP LJ 4700
Oct 06, 2009 | HP LaserJet 4700 Printer
I want to reset counters for fuser and transfer unit. Mike
Hi schoeller:
Hope this helps.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
1. Press MENU to enter the MENUS.
2. Press down arrow to highlight Configure Device.
3. Press check to select Configure Device.
5. Press check arrow to select RESETS.
7. Press check to select RESET SUPPLIES.
9. Press check to select NEW TRANSFER KIT.
11. Press check to select YES.
To calibrate the printer, do the following:
4. Press down arrow to highlight PRINT QUALITY.
5. Press check to select PRINT QUALITY.
6. Press down arrow to highlight CALIBRATE NOW.
7. Press check to select CALIBRATE NOW.
To reset the fuser count
5. Press check to select RESETS.
8. Press down arrow to highlight NEW FUSER KIT.
9. Press check to select NEW FUSER KIT.
The fuser count is reset and the printer is ready to use.
Hope this helps.
Jul 10, 2009 | HP LaserJet 3700n Printer
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
control panel.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
Seeker5211
Seeker5211
