MGI photosuite will not run on Windows 7 - Computers & Internet
proartya8765
  • 581 Answers
SOURCE: Will mgi photosuite 8.1 work with windows 7
You may try installing it in windows 7 and check. If you are unable to install it then I suggest you to install it in windows XP compatibility mode and check. First create a restore point before trying this step.
Posted on Jan 30, 2010
SOURCE: mgi photosuite version 4.0 and
I am by no means a computer expert. somehow I got my mgi to download, by going in and changing what read the cd. I did not install using windows media. somehow I overrode that. BUT...even tho it is installed and working...I get error messages for certain functions. You can hit "continue" 4 times and then it works. Someone told me this would hurt my computer. Any insight?????
Posted on Apr 22, 2010
SOURCE: What replaces MGI Photosuite for Windows 7?
I had no luck with Photosuite 4 on Windows 7, even with backwards compatibility, vista or XP, but Photosuite 8.06 loaded up and appears to work okay, it is older but does seem to work on windows 7.
Posted on Aug 20, 2010
  • 5128 Answers
SOURCE: Running Windows 7 and can't
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, http://www.roxio.com/enu/products/allproducts.html?rTrack=m_pro_all . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
Posted on May 03, 2011
  • 5128 Answers
SOURCE: Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Posted on Mar 25, 2012
Testimonial: "I appreciate the info and even though I do not have time to try the options this afternoon, I plan to work on it tomorrow. Will update then. Thank you so much for the help. Marian"
I have been using MGI photosuite 8.1 for a number of years. Now I have a new computer with Windows 7 and it will not install.I need a 64-bit version of a new Photosuite. Tell me what to get and do....
The MGI company has been bought by Roxio - all their products are no longer updated or supported.
The new ones from Roxio don't offer the same tools and cost more. Instead of them you should get this
http://www.amazon.com/Corel-PaintShop-Photo-Pro-X3/dp/B002J9V9BO/ref=pd_sim_sbs_sw_1
Not only it's much more powerful than what you had but it works on an 64bit 7 OS
Apr 30, 2011 | Computers & Internet
I need to get MGI photosuite that will work with Windows 7 64 bit. where can I find it??
Just today I was able to get PhotoSuite 4 to work in Windows 8 (64 BIT). PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway.
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running.
Apr 23, 2011 | MGI Software PhotoSuite SE V4.0
What MGI Photosuite will work on Windows 7?
I just installed Photosuite 4.0 on Win 7; 64 bit. Works just as great as it did with ME and XP before. Since MGI sold out an error message pops up about some liquid something. I think it is a dead URL to the former MGI site.
Jan 31, 2011 | Computers & Internet
I need free mgi photosuite se for 64 bit windows 7
If you have the original CD's then follow next:
Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running. P.S. 4 worked in windows 7 (update), not full install for me so I assume original I.E 5 files were replaced full install windows 8.
Jan 04, 2011 | MGI Software PhotoSuite SE V4.0
Two computers ago, and two operating systems ago I purchased MGI Photosuite 4 software. I have been using it for about 10 years. I have hundreds of collages saved that require the MGI software to read and...
Wndows installers have changed over the years, so it's not a surprise that the program couldn't be reinstalled. The Roxio Photosuite 8 is listed as a Win2000-XP product; so it may not be the correct release for Win7 either unless you use a workaround. Look here for the current Roxio slide show products: http://www.roxio.com/enu/store/photo.html?rTrack=m_pro_photo
Workarounds: go with a dual-boot or virtual computer system. Win7 Pro and Ultimate let you run a virtual XP computer for free (download two programs - the virtual PC software and then XP mode). All other choices will require a licensed version of XP installed either in the virtual computer program or in a second partition for dual-boot. I've found that files can not be transferred directly from XP mode to the real computer; they must be stored on external media. Then install your software as you would on any stand-alone computer.
I hope this helps.
Aug 21, 2010 | Computers & Internet
I use MGI photosuite and love it. I just bought a
Windows 7 and 8 much the same (32 and 64 bit) you may missing files for Internet Explorer.
Jun 25, 2010 | MGI Software PhotoSuite SE V4.0
Jan 29, 2010 | MGI Software PhotoSuite Mobile Edition 4.0...
Oct 24, 2009 | Computers & Internet
Running MGI Photosuite version 8.05 in Vista
MGI Photosuite on Vista, THE FINAL SOLUTION!!! First you need to get hold of an MGI disc or a download. I have been trying to get MGI Photosuite III SE to install on Vista for months without success and then when I thought I'd finally sorted it I could not launch the program due to a script error. You do not need Virtual PC, Virtual XP or any add-ons. Simply find and right click the the MGI setup file, check the run in compatibility mode as Windows XP SP2 and install. After install, send a program launch shortcut to your desktop, right click, go to properties and check the Windows XP compatibility mode once again. Finally, while you still have the compatibility screen open add a tick check to Run As Administrator. Hey presto my beloved MGI Photosuite is back! MGI is fantastic for being user friendly and simple, and although I know other users insist there are better programs, I’ve tried loads and I still think it’s a winner.
Mar 25, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
