Question about Danby (DAR604BLS) Refrigerator
Frige attains desired temp, shorty after rises to room temp
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Replacing oven sensor on GE Range JGSP31GER1WG
You can try the new thermostat and if the temp is still off, then you you will need to replace the control.
Dec 29, 2011 | Whirlpool Stove Oven Sensor 8053344
Have a new ac system installed thermostat is set at 76 shows room and setting the same all the time shouldn't the room temp rise before unit comes on.
Yes the temp should rise 2 to 3 degrees before the unit comes on, This is called the temp swing, try lowering the temp setting and wait for the temp to drop, then set it back when you want it.
Aug 21, 2010 | Computers & Internet
Hi samsung fridge runs fine gets to desired temp then wont kick in again until it warms up.
the fridge will run until it reaches the temp. there should be a differential of 2 degrees so when the temp rises by 2 degrees the fridge should restart so you will need to make sure the differential is set to 2 degrees celcius on controller
May 21, 2010 | Refrigerators
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
My temp on my fridge is rising. It is usually on
what the problem is the ports that go from freezer to frige are all iced up you just need to defrost a few hours
Mar 12, 2010 | Refrigerators
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressora73b784.jpg should shutdown when setting temp. will attain.
Apr 08, 2008 | Heating & Cooling
Danby (DAR604BLS) Refrigerator Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
