Question about Electrolux Washing Machines
Error e01 electrolux washing machine - Electrolux Washing Machines
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: E01 error in onix washing machine
i use a spatula to stick between the door and machine to push the lever open.....
Posted on Mar 03, 2010
SOURCE: HiI Hve an Electrolux W4139N washing machine that
That model does not exist on our system and Error code 27 does not exist either.If you can find the product number inside the door then we may be able to help you,just re enter your query on the system..
Hope this helps.
Posted on May 29, 2010
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wave touch electrolux error 01
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Washing Machines Logo
21 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
