Pvr decoder stuck in stby mode - Televison & Video
How do i get my hd pvr decoder off standby mode?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 23, 2016 | Televison & Video
When I cancelled my extra view do I lost the option of record and play back on my PVR
probably will . we here at FIXYA have no idea what that company does
Aug 12, 2016 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Sd pvr remote
it sounds like the remote needs to be re-programmed to work with the device. the 2 blinking dots illistrates that it is looking for a device to operate.
May 03, 2012 | Televison & Video
Connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
Dec 15, 2011 | Televison & Video
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Jul 12, 2011 | Televison & Video
4.6v on 3v3 out, then to STBY mode
that is problem of pulse width modulator ic in smps it van be solved by replacing the ic
Mar 09, 2010 | Astec (6500110) 145-Watt Power Supply
I have an error code 01 on my sagem PVR set top box. The manual says perform a programme search then doesn't indicate how. i have tried to press the menu to get the original installation but nothing...
Unplug the box from the mains and leave fro 15 mins. Unplug the antenna (aerial), plug back into the mains and switch on. It will show 09 error; ignor. Press ók'on the remote. The box will reset and reboot into stby. Plug antenna back in and switch on. With a bit of luck you will be able to do an automatic channel scan (refer to your manual).
Er 01 refers to a failed upgrade, so you may have corrupted firmware, which is not good.
Jan 18, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
DO YOU KNOW WHERE I CAN FIND THE UPDATE OF THE SOFTWARE FOR THE SAGEM DTR6400
Your box is updated Over the Air (OTA). I'm afraid I don't hold out much hope for an update anytime soon, but you can keep an eye out for it here...
http://www.dtg.org.uk/industry/download_schedule.php
Make sure your box is set to receive OTA updates automatically and it needs to remain on stby.
Jan 05, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Shows STBY
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
May 29, 2009 | Nikon Speedlight SB-800 TTL Flash
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Electro Med Services...
