Question about GPS
Navigon 14xxx buy car charger - GPS
SOURCE: plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Posted on Jan 23, 2010
  • 9 Answers
SOURCE: Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
Posted on May 09, 2010
  • 9 Answers
SOURCE: Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Posted on Jan 19, 2011
SOURCE: i have a problem my
Same thing happened to me. Hope someone can solve this problem.
Posted on Jan 23, 2011
  • 3 Answers
SOURCE: I have a Navigon 7200T and the car charger is
There are Navigon chargers on Ebay.
Posted on Feb 01, 2011
May 08, 2010 | Navigon 2100 Portable GPS Receiver
How do I give my brand new Navigon 3300 a good overnight charge
if you have a pc, you can use the usb to mini jack and it will charge
Mar 09, 2010 | Navigon 3300 Max Car GPS Receiver
Can my NVG5100 be used for navigation when charging
it should be able to. i have a garmin and it will work while plugged in.
Dec 03, 2009 | Panasonic Navigon 5100
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
When i plug my NAVIGON to car charger he is not working
So, if it's good on the mains !!!
There is a fuse in the Charger's connector,(( on the end of it ))
unscrew the end and check the fuse is good.
Also check the cars fuse hasn't been blown too.
Or battery could be dead, some are repacable,
you can buy batteries online, 2 screws to remove to change it.
Hope this helps
Regards
Ric.
Apr 17, 2009 | Navigon GPS
Plug in car charger and it shows navigon connected to computer
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Screen stuck
Had same problem with a navigon 2100 and after trying my daughters car charger it worked properly. Called Navigon and they are sending me a new car charger.
Nov 27, 2008 | Navigon 2100 Max Portable GPS System
GPS Logo
14 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
