Question about Garden
New snowblower out of the box, the auger handle appears to be locked down, will not come up
    Master:
  • 755 Answers
They may have put something under it , free it up , or the cable is stuck in the insulation work it loose
Posted on Feb 03, 2015
2 Suggested Answers
mikeforrest2
  • 18 Answers
SOURCE: Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Posted on Feb 11, 2013
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
A white 8 hp 26 inch snowblower. the auger will not disengage and the handle stays down
See if a spring has let go where the handle hooks on. . There should be a spring to pull it back up when you let go of it.
Dec 22, 2016 | Garden
The auger wont disengage on a mtD 8 HP 26 INCH SNOWBLOWER THE HANDLE STAYS DOWN
follow the cable to the auger either snapped or came loose
Dec 22, 2016 | Mtd Garden
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Auger belt burns out
un-seize the auger action
replace rusted bearings
Feb 07, 2016 | Garden
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
Craftsman snowblower auger handle won't disengage, won't come up
Any chance it won't come up when you have the "drive" handle down ?? Newer snow blowers are often equipped with a "one hand" feature that will keep booth the auger and drive handles engaged (down) with only one being held.
Jan 30, 2014 | Garden
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 11, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
