Question about Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aquasmart error 245. Hi our Aquasmart stopped working halfway through a cycle. With a 245 code. I removed the pump cleaned out the item and reassembled, it stopped halfway through again with the same code, so we purchased another pump fitted it and tried again, it stopped again halfway through and displayed the same code. Do you have any suggestions? Thanks Brett.
  • 713 Answers
SOURCE: I put a small Carpet piece in my Fisher and Paykel
could b faulty control module. when pump jams or seizes on these machines it usually causes a fault in control module.whenever i found a control module faulty i always checked the pump for cause of fault.
Posted on Apr 08, 2010
  • 713 Answers
SOURCE: I have a Fisher & Paykel AquaSmart top loading
Hi just read your posting.What cycle are you using for the towels?Have you tried a cycle with the EFFICIENCY turned OFF?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 27, 2010
  • 4 Answers
SOURCE: my aquasmart fisher and paykel
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
Posted on Feb 26, 2011
  • 251 Answers
SOURCE: Fisher paykel aquasmart top loader washing
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Posted on Jun 18, 2011
  • 6277 Answers
SOURCE: Is becoming progressively worse with
Sorry, I do not know this particular model- are you certain that it does not have a filter?
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
Why has our washer stopped working through a cycle and why wont it turn on again
The most common problem with AquaSmart is the pump.
The pump has gone bad and blown the motor controller board.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
May 18, 2014 | Fisher and Paykel Aquasmart wl80t65c
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Feb 12, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart WL80T65C 5 years old with fault 245, then 49.
Error code 245 is pump stall.
If the 1.6amp glass fuse has blown, the five mosfets on right side have shorted out there legs & blown the fuse.
Also check the pump drive parts for shorted legs.
There are three resistor that burn out near the fuse.
I will up loaded some pictures later.
Feb 08, 2013 | Fisher and Paykel Aquasmart wl80t65c
What is the service code #245
AquaSmart Error codes
Your pump has items jammed in the impeller.
Jan 05, 2013 | Fisher and Paykel Washing Machines
What is the service code # 245
Jan 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error codes 49 and 245
Fault code 49 is water valves - usually, the stop working when the rubber diaphagm inside gets hard, so a resistance only test is not conclusive (only tells us the solenoid is OK).
- Do a cold fill and a hot fill (briefly) to check for strong water flow on both.
- Regarding code 245, does water pump out strongly?
- One more thought, because these codes are both related to the water level in the machine, remove the level sensor hose at the controller end and blow into it to clear any blockage.
Jan 30, 2018 | Fisher and Paykel Aquasmart wl80t65c
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher and Paykel Aquasmart wl80t65c Logo
19 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
