Question about Bose Lifestyle SA-3 2-Channel Amplifier
Hi there,I have a new SA3 amplifier with one marine speaker 131.and a volume controller Iam trying to connect one dvd player audio out to SA3 and am not getting any output from the amp my LED status is blinking very slowly please help me for solve this issue.
SOURCE: bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Posted on Dec 18, 2007
dobhan
  • 105 Answers
SOURCE: My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Posted on Feb 18, 2008
  • 11 Answers
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
SOURCE: Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Posted on Dec 21, 2008
  • 51 Answers
SOURCE: Volume cuts in and out
Since a CD/DVD player is a digital device, it can be susceptible to such things as power line glitches, interference from other digital equipment and even the ignition interference from nearby passing cars. With older analog gear, you might get a short burst of static, whereas it can completely shut down a digital device sometimes (glitches interrupt its internal program). Sadly, there's nothing you can do about this except plugging the unit into a power line conditioner. You might try jiggling the connecting cables (especially the audio cable), but it sounds more like a random glitch since you can use your remote to fix it. They haven't yet worked out all the bugs in digital equipment, unfortunately. It's also possible that a defect in the DVD player was not caught at the factory during final test.
Posted on Dec 29, 2008
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
How adapt audio from 43 inch hd tv with no headphone jack to vivanco fms 2000 speakers
follow the chart troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Televison & Video
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
How do i connect a aiwa 2.0 speakers to philips dvd player?
In general, speakers don't connect directly to a DVD player (model unknown) as DVD players generally have no way of amplifying a signal to speaker level.
Assuming the speakers were self-powered, you would not be able to control the volume since DVD players generally have no output controls.
I have found nothing online that matches "aiwa 2.0" as a unique speaker model.
Can you re-describe the speakers and the DVD player piece?
Feb 12, 2011 | Audio Players & Recorders
TRYING TO CONNECT EXTERNAL SPEAKERS TO MY VIZIO 42" TV...
Look for audio out plug. this could be RCA jacks right and left or a 3.5mm jack (like a headphone connection on an MP3 player). This is most likely line level output which means you will need to run through an amplifier (or reciever) to get enough signal to drive the speakers. Or you can use amplified speakers (computer speakers will work). You should also have a setting in the menus on the TV for Audio out - this can be set to fixed (controlled by the receiver or amplifier) or variable (controlled by the volume control of the TV).
Jan 13, 2011 | Televison & Video
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
No 5.1 audio
Make sure that the digital audio cable from the DVD player is properly connected to the unit, then step through the Onkyo menus and ensure that the digital connection you used for the DVD player is properly associated with the DVD player's video input.
Jan 02, 2008 | Onkyo TX-DS777
Bose Lifestyle SA-3 2-Channel Amplifier Logo
62 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
