Question about Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aquasmart error 245
Hi. Our Machine stopped halfway through a cycle, displaying code 245. I removed the pump and cleaned the hair ties out and refitted it. I ran it again and it stopped at the same place in the cycle displaying code 245 again. So I purchased another pump and fitted it. It did the same thing again. Do you have any suggestions? Thanks Brett.
  • 28 Answers
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Posted on Mar 07, 2014
  • 28 Answers
SOURCE: Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Posted on Jun 21, 2008
SOURCE: Fisher and Paykel error codes
Think you have the same problem I had ! I changed the water pump and cured the problem. Hope this helps !
Posted on Apr 12, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: new fisher and paykel washer WL26CW fault code 245
the drain pump impeller is seized; you just need to turn it a bit and will work just fine afterwards.
Posted on Mar 26, 2010
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Why has our washer stopped working through a cycle and why wont it turn on again
The most common problem with AquaSmart is the pump.
The pump has gone bad and blown the motor controller board.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
May 18, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
My washer was not totally draining on the spin cycle so I figured there was some blockage. I took off the pump and cleaned out the catch all which had coins, barrettes, hair and muck. I cleaned it all...
This is Error 205 details if it helps,
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Dec 13, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
What is the service code #245
AquaSmart Error codes
Your pump has items jammed in the impeller.
Jan 05, 2013 | Fisher and Paykel Washing Machines
What is the service code # 245
Jan 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
Sand in fisher and paykel washing machine error 245
This is a pump stall error code. Remove the pump from bottom of washer. make sure nothing is clogging pump. If problem persists replace pump.
Oct 27, 2012 | Fisher Paykel Washing Machines
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher and Paykel Aquasmart wl80t65c Logo
599 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
