Question about SanDisk Electronics - Others
Sandisk 16gb memory stick is in write protected
I want to unwrite protected my sandisk 16gb memory stick
  • 289 Answers
This could be a Windows Registry setting that disables you from writing to your flash drive (or formatting it). If you are running Windows after Win XP SP2, you can change that setting.
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Posted on Apr 30, 2014
boogschd
  • 84 Answers
SOURCE: Sandisk memory stick duo
try formatting it
Posted on Nov 02, 2007
  • 46 Answers
SOURCE: Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Posted on Jun 12, 2009
  • 336 Answers
SOURCE: how to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
Posted on Dec 05, 2009
  • 561 Answers
SOURCE: Sandisk 16gb microsd formatting incorrectly
Hi unfortuanley you have been sold a fake card
http://memory-cards-blog.blogspot.com/2009/12/dane-elec-8-gb-compactflash-memory-card.html
Please can i ask that you leave ffedback and vote if this has been useful
Posted on Feb 10, 2010
Use thumb drive
Go to the SanDisk website
you will find product support there
Dec 08, 2015 | SanDisk Electronics - Others
Accidentally switched my sandisk memory to 'lock'
Locking the card simply protects it from writes. It does not wipe out anything that was on it already.
If you're asking about a Memory Stick, there's a switch on the back. Slide it away from the "LOCK" position. If you're asking about an SD card, there's a switch on the side. Slide it toward the metal contacts.
Jan 29, 2013 | SanDisk 16GB Ultra II 15MBS Memory Stick...
How to format write protected SanDisk Blade Micro 16GB USB 2.0 Flash Drive?
i have SanDisk 16 GB Flash it's write protected kindly advice how to remove the write protected from my USB flash.
your kind advice will highly appreciate
Oct 28, 2012 | SanDisk Cruzer Electronics - Others
How to remove write protection from sandisk cruzer 4gb
Not enough rights!
Is there any 3rd party security software, or part of the of the flash?
No? - Then in Windows 7 - Go to Start and check your User Account icon. Are logged in as an Administrator? Guest users have limited access. Switch users or have someone else login.
Oct 14, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When copying around %Gb of mixed files to my 16Gb Sandisk memory stick half the files don't copy. It takes ages to copy, around 30min for %Gb but when I check many files are missing. The stick...
there is a problem on your 16gb sandisk memory, maybe its factory defect or in some cases loosen usb adaptor, no worries, they will replace it
Jul 13, 2011 | Computers & Internet
It is write protected and i want it unwrite protected
There is a switch that says Lock on the side of the SD card adapter. Switch the Lock off and it will not be write protected anymore.
Mar 09, 2011 | SanDisk 1GB microSD Memory Card
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
My SD memory card says its "unwriteable"
There is usually a switch on the adapter you are using that is there for write protection. The Micro sd card does not have one. Make sure it is not in the lock "position". See this website for more on memory cards and common problems. http://www.retire-asia.com/microsd.shtml I cut a little piece from the site that might help you
"There is no switch on the Micro SD card itself, but a standard-size-SD adapter (which the MicroSD needs to be plugged into for use with a card reader) and SD cards such as the SanDisk 4/8GB have a sliding write-protect switch similar to a 3.5 inch floppy disk. Data cannot be written if the slider tab is in the 'lock' position. The tab could be damaged or missing altogether. This is probably the first thing to check if you have an SD card write error problem. Using sticky tape (Scotch tape etc) to cover the switch slot might solve this problem, but it may need two or more layers before it works. Some SD adapters need the tab to be placed somewhere between the lock and open positions before data can be written to the card."
Mar 03, 2009 | SanDisk 2GB microSD Memory Card
Electronics - Others Logo
223 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
