Question about Logitech Z103 2.1 Speaker System - delivers big sound in a little package
My speaker system z103 .the problem is on the left side is not working now..? plz give me any idea how to fix it . thank you
Speaker system z103
SOURCE: Left speaker doesnt work
I have the same exact problem. This is why I don't like speaker cables that are permanently attached to the speaker. Arg. Now I have to go through the hassle of returning these!
Posted on Oct 23, 2007
nkprl
  • 54 Answers
SOURCE: left speakers not working
tell me what sound card you have
Posted on Nov 24, 2007
  • 12 Answers
SOURCE: both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Posted on Dec 27, 2007
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
SOURCE: Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Posted on Jan 24, 2009
Can a speaker system made for PC be used on standard Hifi or Smart TV?
cheap and easy fix for crummy HDTV speakers
TV sound to USB speakers
??? Speaker System needs software??? Uh, if a computer chip in a Smart TV needs software to recognize a computer speaker, you are going to have to get that information from someone besides me.
Jun 05, 2017 | Gateway Audio Players & Recorders
What is the part designation Z103, on rca input of amp, is it cap, resistor, zener diode, can you help ?
Z always represents a resistor. C would be a capacitor and L would be an inductor (choke?)
Jul 17, 2014 | Alpine Mono power amplifier MRD-M1005
Speaker hum
Did you swap speaker to a different channel and put another in its place to see if the problem follows the speaker or stays on that channel? That would me my next move if it's possible to do. Let me know.
Dec 06, 2013 | Audio Players & Recorders
The system WAS working fine. After I moved I installed the system again now the front speakers are not working. I'm sure it's not the cable or the speakers (if i connect in example: the left rear...
The system would have hung up. Please remove the power and leave the set aside for over 6 hours so that the processor will reset if there was any error that have crept into while it was powered . Also remove and reset all the speakers, if possible with an individual test on each- use a 1.5 V AA cell-.
The amplifer can also be reset if there is a note in your manual.
Oct 05, 2011 | JVC TH-A10 System
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
Sony DAV-DZ660 Theatre system. How can I change the output volume and tone for each speaker please?
there should be a speaker set up button on your remote, it will play "white noise" through each speaker in your system, one spearker at a time, as each speaker plays you can adjust its volume, the idea being to balance the system to sound good from your sitting position. try to get each speaker to be appriximately the same volume level. If you have the manual for this system, this setup should be listed in the index or somewhere.
Mar 19, 2011 | Sony DAV-DZ660 Theater System
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
I have very low speaker volume on one speaker, i have checked the system with another speaker....it works
hi,
may be its speaker have some problem. its tweeter is working that's why u get a very low volume through that speaker. change the speaker in side that box and then try.
ok
Dec 23, 2010 | JBL SCS125A System
Yamaha HTR-5850 Receiver Audio -left front speaker output problem
Does the speaker setup fail the same way?
Yes? Internal amplifier problem.
If No - What source(s) do this?
If just one - reverse its Left and Right inputs to determine which cable or channel on the input device is faulty.
May 23, 2010 | Yamaha HTR-5850 Receiver
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
Logitech Z103 2.1 Speaker System - delivers big sound in a little package Logo
82 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
