Question about Breville Coffee Makers & Espresso Machines
Breville BCG450XL start - Breville Coffee Makers & Espresso Machines
My wife accidentally put water in the grinder compartment
the water weight may be confusing the grinder. it may think that it doesnt have a cluster of beans that need to be ground. luckily you might get away with fixing this issue without the aid of newelectronx coffee tool repair set. i would recommend a simpler approach. all it requires is a roll of paper towels. take a paper towel and wipe down all the internal surfaces until the paper towels come away dry without water.
if you have to remove the grinder i would recommend removing the side panels and allow it to air dry before further use
Aug 03, 2015 | Breville BCG450XL Coffee Grinder, Conical...
Can i use my Breville coffee grinder BCG450XL 160v purchased in USA but now living in UK
If you want to use equipment like this, or where 160 volt is printed on, you should use a transformer. 240 to 160 V AC.
Modern small electronic equipment most of the time has 100- 240 V AC on them and can be used all over the world on mains within the range.
Older equipment, or things with motors I should not use.
Sep 13, 2014 | Breville Bcg450xl Conical Burr Grinder...
Why do I get lots of static electricity which causes ground coffee to spew all over the place
you are on the fine grind setting and the coffee dust is flying out? right!. change the setting to something a little more course, and empty the dust from the last grind.
Sep 01, 2014 | Breville Bcg450xl Conical Burr Grinder...
Won't operate; won't turn on
your fuse from inside has went bad replace fuse.
Feb 24, 2011 | Breville BCG450XL Manual Burr Grinder
My Breville BCG450 coffee grinder won't turn on and i have the bowl in place. Can you help me?
I sometimes forget there's an on/off switch on the back of the thing, since I mainly use the button on the side.
Dec 28, 2009 | Breville BCG450XL Manual Burr Grinder
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
