Question about HP Z800 FL938UT Workstation (1x) Intel Xeon E5506 213GHz 3GB DDR3 (1x) 250GB HDD DVDRW w Ligh PC Desktop
Red light on start buttom
No display
Technics sl qd33
tone arm could need cleaning never done it personally but if you take it to a stereo shop they should b able to help you
Sep 19, 2013 | Audio Players & Recorders
I actually have a 250. bulb is new but stopped working. When plugged in green power indicater lights then flashes two red lights.
The projector is bloked, you need reset the lamp timer. Press and hold the VOLUME + buttom, then press the VOLUME - buttom. Hold both buttons down for 10 seconds.
Jun 16, 2010 | InFocus LP 240 Multimedia Projector
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Need a Code Number to work with my Dish
5-Press record
This way of finder code make the remote search 1 by one , usually dvd and other things else than television dont work , but give it a try might work but probably will just power on and off not more than that but will work fine with ur tv
Jan 11, 2009 | Curtis DVD-7600 DVD Player/VCR
I have a bell express vu remote that i am trying to get to work with one of your tv's. the remote is a 3.2IR the model number of the tv is 20pt634v37or 2opt634v37 can u please help me figure out wut the...
5-Press record
Finish :)
Jan 06, 2009 | Directed 434MHZ Remote Control
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
94 deville
TRY CHECKING YOUR PCM CODES BY PRESSING THE (RED) BUTTOM YOU USE TO RAISE YOUR HEAT AND THE OFF BUTTON AT THE SAME TIME YOUR DASH WILL LIGHT UP AND DISPLAY A SERIES OF CODES.............
Sep 15, 2008 | 1994 Cadillac DeVille
Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Feb 09, 2008 | Dishwashers
HP Z800 FL938UT Workstation  (1x) Intel Xeon E5506 213GHz 3GB DDR3 (1x) 250GB HDD DVDRW w Ligh PC Desktop Logo
14 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
