Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah9700aww error code nf - Maytag Neptune MAH5500B Front Load Washer
Krazytech
  • 725 Answers
SOURCE: MAYTAG NEPTUNE ERROR CODE NF
NF is a NO fill..
1 check that the water is turned on.
2 check the water pressure
3 check the nose filter screens
4 check the water valve is opening
5 check the conection on the water valve to the control.
6 replace control board
Posted on Oct 19, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
  • 398 Answers
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Posted on Feb 19, 2009
localwonder
  • 6784 Answers
SOURCE: my maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Posted on Jun 17, 2009
canbruce75
  • 1776 Answers
SOURCE: MAYTAG NEPTUNE ERROR CODE OE
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 11, 2009
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah9700aww error code nd
Remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining.
This will fix your problem.
Apr 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune nf error
My guess is that something got disturbed in the plug when you pulled it off/put it back on. You turn it to "hot wash" and it does nothing? Does it buzz?
Jan 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
NF is a NO fill..
Oct 19, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
