Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
My sandisk 16GB memory stick is write protwcted. how to unwrite ?
Use thumb drive
Go to the SanDisk website
you will find product support there
Dec 08, 2015 | SanDisk Electronics - Others
Sandisk 16gb memory stick is in write protected
This could be a Windows Registry setting that disables you from writing to your flash drive (or formatting it). If you are running Windows after Win XP SP2, you can change that setting.
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Feb 12, 2014 | SanDisk Electronics - Others
Hi My pendrive is write protwcted, Pendrive is
Some pen drives have a small toggle switch with them which make the drive write protected try locating that switch. If there is no such switch then try formatting the drive preferably from safe mode. you can do this by following these steps:
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (Fcool.png key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Sep 23, 2013 | Kingston Technologies 512MB DataTraveler I...
Accidentally switched my sandisk memory to 'lock'
Locking the card simply protects it from writes. It does not wipe out anything that was on it already.
If you're asking about a Memory Stick, there's a switch on the back. Slide it away from the "LOCK" position. If you're asking about an SD card, there's a switch on the side. Slide it toward the metal contacts.
Jan 29, 2013 | SanDisk 16GB Ultra II 15MBS Memory Stick...
When copying around %Gb of mixed files to my 16Gb Sandisk memory stick half the files don't copy. It takes ages to copy, around 30min for %Gb but when I check many files are missing. The stick...
there is a problem on your 16gb sandisk memory, maybe its factory defect or in some cases loosen usb adaptor, no worries, they will replace it
Jul 13, 2011 | Computers & Internet
The lock is missing making it unwritable
Follow this simple guide from youtube:
http://www.youtube.com/watch?v=hJ4D5PPpIJ0
That should do it for ya.
EJ Kudelka
Apr 30, 2011 | SanDisk 2GB microSD Memory Card
Pleeze help, ok i insert my memory card reader and computer recognises, fine, however when i insert my 16gb sandisk m2 memory card.....nada, nothing, zilch!?? It says that there is no media inserted and...
This is because there is a fault in the slot where you put the memory card.
The problem is the memory card contact surface in not in contact with the memory card reader contact surfcae.
So please change the memory card reader it wil be fine.
Thanx
Jul 08, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
Tried it on 3 computers and they can't
Then that stick has died, junk it. USB sticks wore out every time you use them, that one has probably reached its end of life.Next time make sure that you have a backup if you store sensitive data on one of them.
Mar 15, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
