Question about Samsung SCX 4600 multifunction Laser Printer
My samsung scx4600 printer keeps coming up with a paper jam, meanwhile there isnt one. And my second 4600 printer will pick up the paper and half way through get stuck. what do i di
flopez
  • 161 Answers
SOURCE: Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Posted on Oct 04, 2007
  • 159 Answers
SOURCE: my piece of cardstock paper keeps jamming...
Yes, you have to change the print properties on the computer to let the printer know it is using cardstock. Please refer to the owners manual to get the information. The manual can be found at www.samsung.com under the support section.
Posted on Nov 26, 2009
SOURCE: Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Posted on Jan 05, 2010
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
  • 2386 Answers
SOURCE: my samsung clx 3170 keeps jamming up after every
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Posted on Nov 29, 2010
My lexmark 3600-4600 series printer is keep asking for an alignment of the print cartridges. it is printing but seems to be pulling the paper thru off set and all my pages are coming out with off set...
I have had similar problems with a different brand printer. FIRST, unplug the printer and unhook the cable to the computer. I took the paper, cartridges and everything else out that was not firmly attached. I gave the printer a good cleaning including cleaning the pick-off components with a vinegar based solution. Be sure not to get liquid onto the printer electronics.
Feb 16, 2013 | Office Equipment & Supplies
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
HP 2015d While trying to print there is a gutteral noise on the first pass then the paper is picked up on the second pass and then the printed document feeds out. It appears to miss pick up on the first...
first you can try to clean the paper pick up tire, but most likely the problem is in pick up clutch.
TO replace him and rectify the problem you need to dismantle half of printer... call service...
Hope that helps!
Aug 23, 2011 | HP LaserJet P2015dn Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere? and paper is not low????
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Samsung SCX-4600, great machine but I've got a paper jam and I can't get at it - the troubleshooting guide is very helpful for jams everywhere except in this location - the paper has wrapped...
it sounds like it is wrapped around the fuser roller. is the roller around an inch or 2 around? if so it is the fuser roller and be carefull to no scratch this roller or you will get all jams. the fuser can be taken out with care to look at all the plugs and screws.
Jun 20, 2017 | Samsung SCX 4600 multifunction Laser...
Paper jam
at the back of the mashine there is a litle door you can open take the paper out from there
May 31, 2010 | Samsung SCX 4600 multifunction Laser...
HP 1610 first was making a terrible noise when it picked up paper now it doesn't pick up paper at all and keeps showing paper jam, anyone have a solution? I really liked it when it worked
verify that there is not any paper jammed and check the back of the printer if you are sure there isnt ..then the waste assembly needs to be cleaned of waste ink build up... the assy is located on the right side of the printer under the inks
Mar 31, 2010 | HP PSC 1610 All-In-One InkJet Printer
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
Samsung SCX 4600 multifunction Laser Printer Logo
116 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
