Question about Dell Streak 5 Android Tablet
Parsing problem installing apps from sd
I have 408mb but it says i have insufficient space to download an app thats only 9.86mb...what's the problem?
Kindly go with what your phone or tab says please;it's the only way you can go past where you are stopped/stuck at the moment.
1. I suggest you get a micro SD card inserted in your phone/tab.
2. Open settings and navigate to apps/applications.
3. Click on any app you installed.
4. Look midway down and you'd notice two horizontal bars with
CLEAR DATA
and
MOVE TO STORAGE/SD Card
Select Move to Storage (or SD card) and wait for process to complete.
Do this for a number of apps you installed.
This method/tip/option helps free up Space so your tab/phone can allow you install more apps.
Oct 08, 2017 | Tablets & eReaders
It takes a sd card how do i transfer from tablet to sd card
Usually, in the app management section, under each application, there will be an option to move it to the SD card if one is installed. Be advised though, that many apps are not written to be used with SD cards, so for those apps, the option to move will be greyed out. Some allow the data for the app to be on the card, but not the app itself. Others can be completely moved. You will probably be disappointed, as the majority of us have been, at how few apps you can move to an SD card. Mostly, you find it is convenient for storing your photos and not much else.
Dec 10, 2015 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
How do I get a password or code to make my Hisense U939 a hotspot? Secondly how do I load my apps onto my sd card?
Go to the play store and install a hotspot app.
To load apps to sd card, please read and follow: http://www.instructables.com/id/How-to-install-apps-onto-your-SD-Card-No-Root/
Apr 23, 2015 | Tablets & eReaders
How do I move my downloaded apps to my SD card?
You really should check the manual, to see how to move or to install the apps on the SD card. Not all Android tablets and phones work the same. You not giving any detail of yours does not make this easier.
Some systems can install the apps on the SD card and they can run from the card. Others only allow you to put apps on the SD card, but before you can use them, you have to install them in the internal memory.
Again, check the manual.
Apr 19, 2015 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
I tried to download showbox on to my zeepad tablet but now every time I try do to download something from the Google play store I cant
You might want to free up internal storage space on your android tablet. You can do this by moving some apps to an SD card that you have installed. Go to your app drawer, tap and hold on an app, and drag it to "App Info". Then tap move to SD card. Another way to free up space is to uninstall apps that you don't use anymore. If that still doesn't work, try installing a storage cleaning app. I would recommend SD Maid by darken. Hope this helped!
Dec 01, 2014 | Tablets & eReaders
I was trying to install games from my app store on my tablet why did parse error appear
I would recommend restarting your tablet and trying to redownload the app. Usually a a parse error occurs when there is compiling error with the package (app's data).
Essentially it might not have downloaded correctly so restarting the whole process should skip it right along!
Apr 08, 2014 | Tablets & eReaders
Apps do not move to external SD
Install App2Sd(from Google playstore) and then try to move the app after restarting your phone
hope that will work
Dec 16, 2013 | Nextbook Premium 7 Capacitive Touch...
Dell Streak 5 Android Tablet Logo
Top Dell Tablets & eReaders Experts
Michael Vincent Cruz
ray gallant
Xander Lopez
Xander Lopez
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
