Question about HP Computers & Internet
THE REGCURE FINDS PROBLEMS NEEDED TO BE FIXED NOW I DO'T HAVE
I NEED MY LAPTOP FIXED IT FINDS THAT 385 PROBLEM NEEDS ATTENTION
    New Friend:
RegCure will always find problems because it is a problem. Get that software off your PC asap. I refer you to a discussion on Microsoft forums regrading this issue: How safe is RegCure Pro
Posted on Feb 13, 2014
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
Have 1997 thunderbird with V8 4.6L OHC check engine light keeps blinking, don"t have owner manual on car
sounds like there is a code in the computer that needs to be pulled.if it keeps blinking it is probably an emission fault that needs attention immediately.the code is needed first to be able to diagnose the problem or you can throw parts and money at it until it might get fixed without the code.
Apr 16, 2011 | 1997 Ford Thunderbird LX
Physical memory dump at working this error comes after 5 to 7minuts latter when system starts please help
When someone receives the error message,
“Physical memory dump ", usually accompanied with a blue screen. Chances are there is a possible problem with your memory. Before you download memory testing software, let’s try downloading some free software. RegCure is free to download. http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
RegCure will clean windows registry. It will safely remove problem keys.
If RegCure doesn't fix the error message try the next link; http://www.findmysoft.com/news/Free-Software-to-Clean-your-Windows-OS-Cleano-and-Instant-Memory-Cleaner/
Lastly, download & run Memtest86+ at this link; http://www.memtest.org/
Scroll down until you see the 3 screenshots. Choose the testing software to create a bootable floppy disk. This software will test your system memory. If Memtest86 finds a problem you will need to replace the problem memory stick.
Read each site & follow their instructions.
Thank you for using Fixya.
Mike
Download - Pre-Compiled package for Floppy (DOS - Win)
Aug 25, 2009 | Computers & Internet
Error 17? what is that?
Error 17 Codes are caused in one way or another by misconfigured system files.
So, If you got error 17 then there is a 94% chance that your computer has registry problems.
To Fix the problem you need to follow the steps below:
Download and install RegCure Registry Scan for FREE.
NOTE: If the download link doesn't work you may need to Download it Directly from Regcure Site Here.
Mar 02, 2009 | ASUS Eee PC 900 Notebook
CCleaner
RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>> http://www.ccleaner.com/
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM cpenny29@yahoo.com
Oct 24, 2008 | Microsoft Windows XP Home Edition
No desktop icons
well.. right click on desktop.. select view and on the bottom click on show desktop icons.
May 02, 2008 | Dell Inspiron B130 Notebook
Toshiba Satellite P10-804 Laptop Power up problems
Try to remove BATTERY and plug in AC POWER ADAPTER AND START IT.Let me know if it worked?
Mar 28, 2008 | Toshiba Satellite LP154W01 Notebook
Intimus 3850 SE Manual
I have ordered parts for this brand shredder before from shredderparts.com
They are very friendly and had exactly what I needed.
I think they are in North Carolina
Mar 25, 2008 | Intimus 385 se Shredder
Tech com driver
Try right clicking to the My Computer icon on your desktop. scroll down to properties, and then select the hardware tab. The choose device manager and scroll down until you see the webcam and then choose to update the driver. If there is a more current one out there then the updating will generally find it for u.
Nov 29, 2007 | ABS Computer Technologies Awesome 1300...
Problems with power or battery, not totally sure.
Sounds like a power pin issue. Most laptop power pins are poorly designed and poorly constructed. Doesn't take much tugging or pulling to break them loose inside and cause problems. The part is only $ 5-10 but the labor to replace the part is $ 100-250 depending on who does the work.
Once you get it fixed you need one of these. . . In fact EVERY laptop needs one of these. . .
Jan 08, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
